0 Members and 2 Guests are viewing this topic. Read 27366 times.
Scotty, good that you got it working & it always works when you follow this procedure, right? Not works sometimes & other times not, right? But no need to Paste the file, just copy & then start the MQN.BAT - have you tried that?So, raysracing, if you follow Scotty's example is it working? I don't know what you mean by "setting up WASAPI & USB" - as Scotty says your soundacrd that you want to play through should be your default soundcard
My USB interface if that is the correct term is the Paul Pang USB 3.0 V2. But the sound card I believe is just the stock one on the motherboard. I am just wondering if there is no communication within my computer due to the Paul Pang? Ok so I hooked up the DAC to a generic USB on the computer and still no sound.
I tried Scotty's method with the "paste" and no sound.
My USB shows an incoming signal though as the sample rate is lit up.
***edit:when I try and play a 16/44.1 WAV the COMMAND PROMPT flashes, but the DAC does not change to 44.1 as it was on 48 for the previous track on Jriver. There has got to a solution so that MQN gets communication with my sound card or something.
Ray,I had an issue a one time with not being able to play MQN. Here is what helped me to get it working, Download and attempt to play your wave files using "PlayPCMWin". If you are able to play music with this, afterwards you will be able to play it with MQN.
So I'm resurrecting this old thread because I've been trying to get MQN running.I tried a couple nights, couldn't get anything, but I finally had success tonight I downloaded MQN, and also mqncontrol https://www.dropbox.com/sh/u71wm4ki02vdvg6/p-DhIcn5L0I also had to disable UAC and run the "normal" version of mqnplay. The avx2 didn't work for me.With that I have music.I will compare mqn to some other playback software and see what I think.Randy
MQn setup has changed, I figured it out last night, and created a blog with instructions.http://randytsuch-audio.blogspot.com/2015/10/mqn-setup.htmlI'm going to add some more information to the instructions, like if MQnload still works, how to do flac (once I figure it out) and foobar/mqn (if I figure that out too).But what is there should get someone started.
