Check out MQN
0 Members and 1 Guest are viewing this topic. Read 27461 times.
mjock3
Re: Check out MQN
« Reply #20 on: 23 Oct 2013, 06:26 am »
So now you change it to cd where your music is located. And you should be set to go. :)
wushuliu
Re: Check out MQN
« Reply #21 on: 23 Oct 2013, 06:30 am »
You mean where mqn folder/bat file is located, correct? Not actual music library (unless they are one and the same).
There is a Readme text in the previously linked directory with (admittedly unclear) instructions:
Installation - there is no installation or registry modification
Just download the MQn.bat, paste.exe and the latest version of the MQncontrol.exe and mqnplay.exe that meets your needs (see below) to a directory eg c:\MQnPlayer
remove the versions from the end of the files eg rename mqnplay.exec2.0 to mqnplay.exe
change the 3rd line in mqn.bat to point to the directory with mqn.bat in. eg cd c:\musicplayer
[/i]
mjock3
Re: Check out MQN
« Reply #22 on: 23 Oct 2013, 06:42 am »
Nope, where the music is located in your setup. Isn't that how yours is working?
It is how mine is working.
I keep the MQn.bat, MQncontrol, Paste, & MQnplay all in one folder.
Mark
wushuliu
Re: Check out MQN
« Reply #23 on: 23 Oct 2013, 06:52 am »
Mark
All my mqn stuff is in a mqn folder on c: drive. My music library is on another drive. My bat file is edited to reflect the location of the bat file on the c: drive.
mjock3
Re: Check out MQN
« Reply #24 on: 23 Oct 2013, 01:46 pm »
Sorry wushuliu, your right.  :duh:
I don't know why mine was working.?
this_is_vv
Re: Check out MQN
« Reply #25 on: 24 Oct 2013, 05:22 am »
how to make it work...all my files are in c:\mqn folder and the bat file is showing that folder but when i click it opens up and then just closes nothing happens..
V
wushuliu
Re: Check out MQN
« Reply #26 on: 24 Oct 2013, 05:34 am »
V
Just so we're on the same page: did you install the files from the main google link? Are you using newer (say 2.59-2.69) mqnplay.exe? Did you read the full Readme instructions from that link?
Also make sure anti-virus is turned off (at least while you test) I think that caused errors in my setup.
wushuliu
Re: Check out MQN
« Reply #27 on: 24 Oct 2013, 05:56 am »
Here are some step by step instruction as I think the Readme is a little confusing and omits some information:
FYI - MQN is for x64 W7 and W8
Go the Main directory here:
https://drive.google.com/folderview?id=0B3vvH5WBfg8PdlZmeDhNZ1Utbm8&usp=sharing
Download the following (hit the 'List' tab at upper right of screen for a more manageable view)
Mqn.bat
All four Mqncontrol.exe versions
Mqnplay.exe 2.70 (or whichever has most recent date - not number)
Mqnreadme
Mqnstop
Mqnpaste
Create a folder for all these files
Right click on Mqn.bat, select Edit
Change 2nd line with 'cd c:\ etc.' to 'cd (insert bat file location)  e.g. cd c:\mqnfolder etc.
Save and close bat file.
For convenience I recommend changing the file folder to match what's already in bat file (c:\musicplayer) at least for testing
Select one of the mqncontrol.exe's *if you have a dual core select a core 2. If you have quad core any will work*
Rename selected mqncontrol ('mqncontrol.exe no affinity v2' to just 'mqncontrol.exe')
Rename mqnplay.exe X.XX etc to just mqnplay.exe
Reboot
Select track or tracks, right click, copy
Double click mqn.bat
Then  track should play
Then try out the different mqncontrol.exes and pick which sounds best
Same goes for mqnplay.exe. Go to Archive directory and try out older versions.
this_is_vv
Re: Check out MQN
« Reply #28 on: 24 Oct 2013, 06:05 am »
Mqn.bat
Mqnreadme
Mqnstop
Mqnpaste
thanks for help....not helping yet.....here is screenshot with what all in my directory...
V
wushuliu
Re: Check out MQN
« Reply #29 on: 24 Oct 2013, 06:14 am »
V
Can't quite see it but it looks good. Did you reboot?
this_is_vv
Re: Check out MQN
« Reply #30 on: 24 Oct 2013, 06:19 am »
yes sir....no luck yet....
V
wushuliu
Re: Check out MQN
« Reply #31 on: 24 Oct 2013, 06:22 am »
V
Forgot to mention the program is listed as being for 64bit only. Is yours 64?
this_is_vv
Re: Check out MQN
« Reply #32 on: 24 Oct 2013, 06:44 am »
yes windows 7 64 bit.....checked....
V
wushuliu
Re: Check out MQN
« Reply #33 on: 24 Oct 2013, 06:51 am »
V
Hm, then you'll want to mention it to Gordon the designer. Hopefully he can help. He's at this mqn forum:
http://www.tirnahifi.org/forum/viewtopic.php?f=8&t=2418&p=47002#p47002
I'm still learning about it myself. Sorry I can't be of more help.
this_is_vv
Re: Check out MQN
« Reply #34 on: 24 Oct 2013, 06:52 am »
ty so much for all the help already....
V
mjock3
Re: Check out MQN
« Reply #35 on: 24 Oct 2013, 02:17 pm »
V,
Are you music file wav?
this_is_vv
Re: Check out MQN
« Reply #36 on: 24 Oct 2013, 02:31 pm »
V,
I have all type but one I am testing this software with is WAv
V
mjock3
Re: Check out MQN
« Reply #37 on: 24 Oct 2013, 08:22 pm »
Something else that comes to mind. When you copy the music, is the location of that music copied at the same time?
this_is_vv
Re: Check out MQN
« Reply #38 on: 24 Oct 2013, 08:52 pm »
I tried both ways...ihad wav file copied in same directory also then copy wav in different folder and clicked copy and then clicked on bat file...
V
wushuliu
Re: Check out MQN
« Reply #39 on: 24 Oct 2013, 09:29 pm »
Know it sounds like a hassle but I'd just head to the mqn forum... I do think it's worth the effort.
