0 Members and 1 Guest are viewing this topic. Read 27479 times.
V,I am looking at your screen shot, what is the 5th file from the top. I can't see clear enough, but I don't think it should be in the folder.
When i run this..it is file that tells what files they saw in the copy part....it has generally all the names i coped to run in the MQnV
Did you shut off any anti virus stuff?
wushuliu, I followed your directions and it still won't come up and run. I even went into Properties, Security and Unblocked each exe.I also followed the recommendation to set Pro Audio Background True.Still no dice. It sure looks simple to setup but the devil must be somewhere in the details.I am able to use PlayPcmWin which sounds pretty good.http://code.google.com/p/bitspersampleconv2/wiki/PlayPcmWinEnScotty
Guys,You should have 2 files created in your MQN folder when you try to run MQN - they areFiles.txtParam.txtThe contents of both should be the full pathname of the WAV files you are trying to play.Is this the case?
