0 Members and 1 Guest are viewing this topic. Read 20666 times.
Freo you gave me hope for few minutes.Unfortunately Yamaha A-S2000 is 90W nominal rated and will send my Fostex FF125WK to heaven in few minutes. JLM nice to hear from you. It is a bass reflex design I built few months ago and absolutely in love with it. It is built for roll off at about 70 Hz(Thanks to MJK). So it needs a sub to help.I am planning on a sunfire HRS10 or SVS sub to support them(that is separate money). I will consider used(but not vintage). Having a remote is a plus.High pass through is when you send the line level signal to sub and the out from sub to amp configuration?
I'd definitely check out the NAD amps. They make several nice integrated amps that will give you good sound within your budget.
Uhh, I think I made both those suggestions in post #4... Just sayin'...Fostex should be able to recommend a suitable fuse that will protect the speakers from long term overpowering while letting dynamics shine.
Freo no offense,but that is not very accurate.please read this article which states at the end "If you are looking for a recommendation so that you would be relatively free ofblowing up the speaker under almost any real world condition, you should pickan amplifier that can deliver the continuous rating of the speaker or a little less."http://www.peavey.com/support/technotes/poweramps/HOW_MUCH_POWER.pdf
