0 Members and 1 Guest are viewing this topic. Read 20667 times.
Rex, a volume control in pre amplifier has very few things to do with the power being delivered to a speaker.Pre amplifier ONLY adjust the gain ,in my understanding. If you try to deliver 100 Watts RMS power to a 50 watts nominal rated speaker the chances are that one of those days you may burn the speaker coil. As long as there is no signal at input of the amp , the power delivered is 100 watts for a 100watt rated amplifier. You can attenuate the input signal ( by using a pre amp) but does not guarantee that it may not clip the signal depending on the source output signal level.( for example for squeezebox see how it is explained (http://wiki.slimdevices.com/index.php/Connecting_directly_to_a_power_amplifier) . Again most speakers handle the power-surge unless it is tremendously huge,because heat can be dissipated .But if that persists you will end up with a burned speaker,amplifier or both. When there is clipping we unknowingly turn down the gain (most of the time) so nothing happens in all practical situations. The power delivered as sound is near what you all said,about 1-2 Watts ,because that is the efficiency of most of the speakers,rest being dissipated as heat in the voice coil. It is not because you are delivering 1 watt to the speaker from your 100 watts amplifier but that's all you can achieve with a moving coil speaker.
Do you think sphinx has a remote of some kind?
An optional remote for $100 is available which controls volume only.Steve
"Mute" button? (For phone calls or when "Publisher's Clearinghouse" rings my door bell with a $50M check as big as a house.)
Any system that contains a volume control will accomplish this...even a system with a 2,000 watt amp. Don't limit yourself to a specified power range based on where the speaker blows up. Search this site for "how much power do I really need" type posts and you'll quickly find that you usually use less than 1 watt and rarely over 20...regardless of the wattage of the amp. That is, unless you have rocking uber-loud parties and such.
I would wager money a nice Redgum RGi60 would be better than any of the options mentioned and comes in at 60wpc.I have never owned nor heard an RGi60, but I have own an RGi35, RGi120 and RGi120 ENR.http://www.digitalaudioreview.net/2013/03/redgum-rgi60-w-magnepan-mmg-6moons-review/
Turn, turn, turn. Never the trust the numbers on the spec sheet. Out in the wild, there’s the never-ending talk of the need for big watts to get you out of the Magnepan woods.
I'm shocked to find an audio reviewer who's writing quality is below Srajan's. Darko establishes the new benchmark on the left side of the bench. Congratulations, John.
Don't colour this. Tell us what you really think!
When you look up to Srajan's writing, that's not good.
