0 Members and 1 Guest are viewing this topic. Read 10997 times.
Not that this has much to do with active bass panels but simply changing tubes in a preamp can have a significant impact on the amount of bass that they're capable of. You'll still need the amplification, of course, but they're not bass shy speakers by any means. They all may not go down exceedingly low but what they can reproduce is very, very good sounding.
Not in their business, but I don't see enough of an upside to Magnepan.
If you had an active/self amplified bass panel it would direct more wattage to the bass and would therefore make them more dynamic. It would also take the load off of the mid/highs and this would mean less powerful amps would be able to drive them.Only upsides if properly implemented in my eyes.Jim
Regarding "more efficiency": Not physically possible. The efficiency of the transducer is defined at construction and no amount of increased power, elimination of high-level crossover, bandwidth limiting, etc, etc, will increase the efficiency of the system."Oomph" is a subjective term and completely meaningless. However, all other things being equal, if you changed amplifiers to one that has considerably more power, I would stipulate that more "oomph" might be the result.Cheers,Dave.
However, it surprises me that another planar maker hasn't (as far as I know). Most go with Amped Coned Bass, which can be rather good, but there isn't the flexibility for placing the sub part of their panels logistically in a room. With Panel bass, it would be a less of an issue. Jim
