0 Members and 1 Guest are viewing this topic. Read 28595 times.
but it is about price. if it were possible to spend $100 total and have a great sounding vinyl system everyone would have one. vinyl costs more than digital, so if you can't make the investment, I wouldn't get into it. that's ridiculous about it being hard to setup. one of the best sounding tables out there can be setup perfect in 15 min with no special tools. like anything, if you scrap together a bunch of old junk you are going to spend a lot of time trying to get it all work properly, which probably will never happen.
I have to wonder then why it's such a common excuse for poor or mediocre sounding LP setups at audio shows (i.e., it's not setup right)?
Price isn't what I'm talking about. Although in this day and age, price isn't as solid a determiner of performance as it once was. A lot of things are also overpriced..It's the extreme fiddlyness. Make sure this and make sure that. Set this and set that and make sure you use this with this. People hear all the time "oh vinyl is the way to go", but if you can't make it sound incredible out of the box, better than an Ipod, it will never re-take off. It will just be another quick passing fad.For the record- ha, for myself, I'm still interested in getting back into it. I want to try the U-turn Orbit.
Unfortunately you are beyond wrong. It's no less fiddly than digital. You're conflating average consumer needs vs. audiophile. You do realize that you can purchase new set-it-and forget-it turntables, right?And this from a person with Maggies. Like you can just put any old amp on those!
Are you speaking from personal experience?
RClark and others, let's please not turn this into a digital vs. vinyl thread, except in the context of seeing if we can help bring OP's vinyl set-up to a higher caliber.
Digital is basically irrelevant to the discussion at hand. I think if WireNut has the good fortune to acquire a good sounding phono-stage he will be much closer to being happy listening to vinyl.Scotty
I first tried to set overhang on my TT based on the info from the manual at 2.047 from the stylus tip to the end of the headshell washer. Then I got the alignment protractor from vinyl engine and it was easy to see that my initial setting was off. I think the vinyl engine protractor is a good tool. I like it. As far as cleaning the albums goes I started out by using my Allsop 3 Orbitrac but that just seemed to push dirt around so now I’m cleaning them in the sink with a soft sponge, luke warm water and a couple drops of dish soap then drying with terry cloth and a dish rack. Also, I came across some inner and outer sleeves called “Blake Sleeves” from ClearBags web site which I plan on purchasing to protect my albums. Boris at Vista Audio has a MK2 version of the phono-1 preamp which allows user's to set cartridge loading and gain for $299.00.I'm getting one real soon.
Wire Nut PM me your address I will send you my Vista to try out , see if it helps you.Great little beginner phono pre, and Boris is a great guy.Mike
