0 Members and 2 Guests are viewing this topic. Read 142928 times.
Thanks, John. I have 4 mid-range drivers so it sounds like I'll need to check each of the 4.1. When you say take a screwdrive and "turn it", I'm not sure what it is having never taken the VMPS apart. Tomorrow night I plan to visually inspect the 4 mid-range drivers there but thus far I've no idea what to expect. I'm fairly mechanically inclined but electronics and speaker challenged. And soldering iron challenged.2. If it turns out to be L-pads, are replacement L-pads available out there and might this be something I can replace?3. Is it close to impossible to locate Neopanels these days? 4. Do you happen to know if the mid-range drivers are daisy-chained such that if one blows all cease to function?5. If a crossover, are there any similar crossovers available if this one can't be rebuilt?The RM-40's have been fabulous and trouble-free until tonight and I'd hate to consider alternatives.Very much appreciated, thanks.
Hi Stehno,Did turning the midrange L-pad restore sound? You didn't say.Also, not to sound blunt, but we can't guess and tell you what's in your speakers. Speakers have impedance ratings. But, that's a static figure, as resistance varies with frequency. So, having a 4 ohm speaker, doesn't mean you'll have a 4 ohm L-pad. In this instance, you'll have to pull a woofer, and investigate. You need to match what's already there. No choice.Since L-pads come in different impedances, you need to know if you have a four, eight, or sixteen ohm L-pads in your 40s. Using the incorrect L-pad can shift crossover points. Bypassing the L-pad, can shift crossover points, since that would change resistance.As to power handling, everything wired to you amp absorbs and dissipates wattage. The speaker wire, all the individual speaker drivers, and all the crossover components, including the L-pads, absorb power. So, no one component sees your 1100 watts. Which is a good thing, because you could have burned out the whole speaker, as a result of the party mode playback session.One other thing to think about when replacing the failed components, you might be able to bump up to a part with greater power handling, but should you? If the midrange L-pad is what failed, swapping in a higher wattage pot may prevent failure in the future? But, in your case, the L-pad acted as a fuse, and hopefully saved your speakers. A higher wattage L-pad may save the L-pad, but allow the speakers to fry! What would you rather do, spend a few bucks on a new L-pad, or try and source expensive, rare drivers? Your choice? Oh, I'd also fuse the speakers, or buy Cerwin Vegas! Again, your choice. Good luck.
I pretty sure this is the L-pad (#260-265 , 100watt, 1” shaft, 8 ohm ) for RM 40, both L-pads in my 40’s are the same (100watts). But you still want to check what Brian used in your speakers. Good luck Zakhttps://www.parts-express.com/speaker-l-pad-attenuator-100w-mono-1-shaft-8-ohm--260-265The best way to access the L-pads and crossovers is to lay the speaker on it side and remove the base and the passive radiator.Pictures of RM 40 L-pads and crossoverLeft L pad for tweeter ( green and blue wires ) Right L pad for midrange panels (red and red/green stripe wires)
Hey, Skimpy. No. Turning the mid-range L-pad did not change anything. But I will try once more whil by gently turning the L-pad out from the 12 o'clock position to maybe 10:00 o'clock or even 2 o'clock to see if that changes anything.
I did presume that you and others here had VMPS speaker specific knowledge, sorry my bad.
Party mode session? Um, yeah, I suppose I have my guilty pleasure moments playing at 103-105db. It's as important to me as a nice classical or instrumental piece at 87-95db.
Good points on not changing things out and hence potentially changing the weakest component in the link blowing.
Good suggestion on installing a fuse. Bad suggestion on installing a pair of Cerwin Vegas. If I'm able to get things working again, where would be the best place to install, before or after the x-over? And do you know the criteria for installing the appropriate fuse?
BTW, would you still guess that it could be the midrange L-pad?
Much appreciated,
I was hoping for sound.Unfortunately, Brian didn't publish VMPS documentation. So, it's difficult to know what's inside a particular model without actually owning it. One thing I want to work on. Start a thread, trying to catalog documentation and schematics.I was being intentionally rude. Sorry about that, but I didn't want you to (further) damage your speakers.As above. Caution with the volume control.Fuse wiring diagram, from my Acoustic Research manual. No reason this won't work for your 40s.http://www.classicspeakerpages.net/library/acoustic_research/ar-9_series_1978-1981/ar-9_series_manuals/ar-9_manual/ar-9_manual_pg25.htmlThat's just a guess. But, I'd think it's most likely, due to all 4 panels failing at once. I'd look at the L-pad first, and the midrange crossover capacitor second.You are most welcome!
Stehno, Really glad there working. There really not that difficult to tilt down on there side, and they out weight me by 65lbs. I think bases are actually two pieces, but you have to remove the 4 large Phillip screws (approx. 4”) first. That removes the base from speaker. Then you can remove 8 screws (1.5 -2 “) that hold the bottom to the side of the base. Good luck Zak
