0 Members and 1 Guest are viewing this topic. Read 17776 times.
Two issues:First if a capacitor is used at significantly below its voltage rating, as you propose, it may not operate at its rated capacitance. I would not deviate voltage values as much as you are thinking about.I think you have it all wrong. I want to replace a 5.6uf 250v with a higher voltage unit. i.e., 400v, 600v or 630v.
I think Frank is saying you are better off sticking with the original voltage if you can. However I don't see going up in voltage as a problem. If you have the same brand of cap available in different voltages, go with the one that is closest to the original.Caps in the same brand but with different voltage ratings can sound different.You won't damage anything by going up in voltage value. If you have the cash, try Mundorf silver/oil, or Clarity Cap MR series.Steve
A few thoughts come to mind when it comes to crossover caps.1) If back to back Electrolytic or even bypolars are used below their voltage rating, yes the capacitance will change. However, I know of very few who uses electrolytics. With films, no sweat.
Thanks all,There is one Electrolytic 100v 10uf, will that matter?
Standard wire-wound cement types are neutral but dull, they sound a bit closed in.Metal-oxide (MOX) are brighter and have more detail. They are a bit edgy if your system is already on the bright side.Carbon Film like the MOX they have more detail than the cement types and are smoother than MOX.Mundorf M-Resist Supreme very open, neutral, good dynamics, smooth and open.Duelund Silver Graphite resistors on the same high level as the Mundorf's but with added natural harmonic overtones and a little more air in the top end.Caddock MP-930 clean, detailed and smooth. Neutral tonal balance but not as spatious as the Mundorf or Duelund.
Does it matter if I used teflon, cotton or PVC jacket hook up wires? Copper or Silver? I also plan to change all the internal wiring.
I'm sure Ethan Winer will be here soon....
