0 Members and 1 Guest are viewing this topic. Read 17781 times.
When I compare the Epos to my Focal 807V, the Focal top is brighter.
How you like the JD9?
Stereophile has measured both speakers. The Focal seems brighter because it is, exhibiting the 'smileyface' response of bass and treble. The Focal tweeter has a sharp spike around 14k and is just generally brighter, meanwhile the Epos has a slight rolloff the more you listen off axis. The Epos seems the flatter speaker overall. That Focal spike and treble would probably drive me crazy.
Hi,I am thinking of replacing the capacitors in my crossover. Does it matter if I replace a 5.6uf 250v with a 5.6uf 400, 600 or 630 (v) capacitor?Will it cause any ill effects?
Kinda little tangent...have any one heard about the Russian PIO capacitors....see some real good review and vost benefit around the web.,...V
