0 Members and 1 Guest are viewing this topic. Read 50348 times.
Now that you mention it, QE, it would be interesting for Tom Danley to re-design the SH 50 for home use - scale it down. I imagine it would be feasible. There does seem to be an excessive surplus of dynamic capability for living room or even home theater use!
i would think the sm60f is what you are looking for. needs subs but better high frequency response. and, i think the sh50's need subs anyways...i also like the looks/specs of the sm96, but it's a bit larger...doug s.
Yes, 131dB peaks, 99dB/W/M, 66Hz-24kHz ±3dB, 1,600W power handling and 50lbs vs 130 lbs, not to speak of 60°x60° dispersion look like good numbers, but I can't help wondering whether the mids and top being covered by a single 5" coaxial doesn't make this a fundamentally different sounding speaker. Also, I notice Danley calls the SH50 their "flagship speaker" and mention low distortion in their description - "For high SPL and low distortion sound reproduction". That phrase is missing from the SM60 description. Also, It's hard to rationalize the performance differences, given the SM60 has 2 - 8" bass drivers and a coax 5" and the SH-50 has 2 - 12" bass drivers, 4 X 5" mids and a 1" HF driver, yet the sensitivity difference is 1 dB, the power handling (continuous) is 800 and 1000 W, and the max spl is 131 vs 133 dB. I am guessing the SM 96 has the same components as the SM60, but in a larger box which enables lower bass extension, but sensitivity and max spl numbers are 1 dB inferior to the SM60. It looks to be designed as a floor wedge, where the low end extension would be plenty.
the sm96 frequency response is listed as +/-3db; the sm60 is +/-4db. i'd rather have a tighter frequency response at a slight loss of efficiency/max spl...doug s.
I do not think this 1 dB extra precision (measured not in real rooms) has any relevance when the speakers are in real rooms. Because of the wider dispersion in the majority of the rooms probably much easier to place the SM60F well, then the SM96. I believe the 60 x 60 dispersion is a bit better for average size room than the 90 x 60 dispersion.
PaulWhat do you think of them now that you've had time with them to compare to the UcD?
JTWRace,Sorry it has taken me so long to respond to your question. I don't want to hijack this Danley thread with a long reply, so I will try and be brief.The Hypex Ncore400s replaced Hypex UCD400HG modules in my system, so understand that my reference amps were also of very high quality and based on identical technology, by the same manufacturer.I don't think there is any significant difference over the UCD400s in the bass and midrange. However, I have convinced myself that the treble is just a bit smoother, detailed, and easier on the ears. Being an old grizzled engineer, I would love to do a double-blind test to prove what I just said, but I do not have the necessary equipment to perform one. When I switched from an Audio Research Classic 60 tube amp to the UCDs a few years ago there was no doubt about the difference, but I am far less confident about the audible improvement of Ncores over UCDs. Of course, I am confident my 71 year old ears are not as golden as most on this forum, so my observations may not be worth much.That's about it. Not very helpful I'm sure, but I have to call it as I hear it!Paul
I wanted to share what I heard of the speakers but did not want to name my source as it was a private conversation I had about the speakers. I will share the email but keep the person's name out of it as I think he would be o.k. with that. This is not just some audio hobbiest talking, trust me. I only share this for discussions sake and have absolutely no beef with Danley, or want to cause any issues with them. Everyone has their opinions, so take it that way. "Recently, I have had "the pleasure" to hear the famous Danley synergy horns, specifically the Danley SM 60F model. I don`t know how much you`re familiar with their design, but let me just point out that some audiophiles went completely crazy over them.At some audio forum someone said he owned the Avantgarde Trios, but sold them when he heard the Danleys. He said Danleys outperformed some heavy competition from the big Wilsons, Magicos, JM Labs, etc. Even on some local forums here in my country people started to rave insanely about them.Now, if you remember, I have already mentioned I have experimented with horns really extensively for a few years. I`m completely aware of all their pros and cons and am very familiar with their general sound.I went to check their design attributes in detail and was immediately able to imagine the type of sound they would produce, just according to their dimensions, driver arrangement in the horn throat and everything else. Despite all that, I thought, what if Danley somehow miraculously cured all of the typical horn problems?I went with a friend of mine across the country and listened to the two systems with Danley speakers that were supposedly superior to everything else.I`m not sure I have the will to explain everything in great detail, but if I say that I was disappointed would be a massive understatement.The moment the music started to play - I hated myself for travelling such a long distance just to hear the mediocre public address system!Horn honk and HOMs (higher order modes) were just unbearable. There was no upper bass/lower midrange (the fundamental frequency region that all music is built upon) to speak of and the horns were just plain simple annoying.I know very well how Avantgarde Trios can perform and their sound is balm for the ears, compared to Danleys. OMG..."Rocket_Don't Shoot The Messenger_Ronny
This report is no bullshit. I am the friend who the anonyimous went to listen the DAnley. And I can say the same as written by ronnie or the ... Sadly but true.
