0 Members and 1 Guest are viewing this topic. Read 23581 times.
Tube amps work well as long as they are 100 or so watts per side. Jolida JD1000 is a good option. I have found tubes the ONLY way to prevent the brightness issues that plague Maggies. When I say tube amps - I am not referring to hybrids...
I've had many pairs of Maggies in various rooms over the years. Your room is too small for 1.7's. Maybe MG12's, but they are on the large side. You cannot listen in the exteme nearfield with line source speakers.
The supplied resistors (or other resistors) or some sort of biamp arrangement that allows reducing the drive to the tweeters MUST be utilized to bring the tonal balance in line.
Some of the early CJ's had very luscious, tubey, euphonic sound. I'm not sure you'll get that kind of sound out of any solid state amp, or out of the more neutral amps that are being sold today.
Let me suggest you look at the Sanders amps.
Anyone else think it's a shame tone controls went out of fashion? They were far from perfect, but better than having to choose a one-size-fits-all solution that doesn't work.
I tried the 1 ohm resisitor on my 3.6s and agree with you. I settled on the Mills 0.75 ohm and found it to be ideal
I used to have a Mcintosh amp a MC352 but it ran out of power at higher levels. When I went to the Brystons I noticed more brightness than with the Mc amp. I went to a tube pre-amp and problem solved.
Boy, I sure do. Nowadays it seems the quest is to mix/match components in search of some "synergistic combination" of equipment to yield the right tonal balance, when some simple tonal adjustment might be all that's necessary. Also, tone controls nowadays can be much more powerful and focused than the crude implementations of years ago.
