Deleting files in the 'Recycle' folder
0 Members and 1 Guest are viewing this topic. Read 2157 times.
myview
« on: 4 Jul 2012, 06:14 am »
I have 2 x 1TB drives attached to my BDP-1 which is connected to my LAN environment.  There is a 'Recycle' folder created in the main directory of one of the 2 drives.  In this folder, there are many files which look like system-generated trash (mine runs to 40GB).
Has anyone tried deleting these files in the 'Recycle' folder?
saveloy
Re: Deleting files in the 'Recycle' folder
« Reply #1 on: 4 Jul 2012, 04:50 pm »
Yes, I deleted that folder & that folder from the computer recycle bin.
But with the newest firmware update I now have a few files that I cannot seem to delete.
Kyri
ronman
« Reply #2 on: 4 Jul 2012, 06:51 pm »
I have not linked / networked  my computer to the stereo system. I am in the habit of taking one of the hard drives from the BDP-1 to the computer, emptying the recycle bin on the computer, then connecting that hard drive to the computer.    I do a bit of hard drive maintenance on a friends hard drive he has connected to his BDP-1. His ipad shows a heap of files that have dollar sign icons and numbers in the recycle bin folder on his BDP-1 hard drive. I just connect that drive to his laptop, delete that folder, and transfer any fresh downloads he has to that hard drive. He once had a strange folder we could not delete, so as he had a spare hard drive with his music backed up on it, we merely formated the BDP-1 hard drive, copied the back up music to the drive, then all was good again.
zanetto
BDP-1 questions I can't find the answer to
« Reply #3 on: 26 Nov 2012, 04:21 pm »
1) When disconnecting a hard drive from the back of the Bryston BDP-1, do I have to power off the Bryston?
2) If that drive is  a powered drive do I have to power it off?
3) Should I power off the Bryston before removing thumb drives?
4) Presently I'm using iTunes to rip CDs to a MacBook Pro to AIFF files. My concern is that I keep the resolution as high as possible for best sound...can I improve upon this?
5) Is there any MAC OS software that will help me organize my music? Presently I'm creating folders and sub-folders , naming them, organizing them in genres then individual artists when there are multiple albums e.g. Jazz, POP, Easy Listening, Male/Female Vocalists, Classical (Orchestral, Keyboard, Baroque, Chamber Music, etc), Choral. This is the most time-consuming part of all. How do others organize their music? By the way, I've been using MPaD with an iPad and it seems to work great.
6) I am using two Seagate 2TB powered hard drives: one strictly for connection to the Bryston, the other for backing up my files. What is the fastest/easiest/safest  way to backup? (Do the length/quality of the connecting cords affect the results in any way?)
7) Is there a limit to the size of thumb drives that can be used with the BDP-1?
THANKS in advance for any guidance, suggestions.
This is my first forage into this kind of thing, the I'm incredibly impressed by the BDP-1!
  • The Demo is Everything!
    • http://www.bryston.com
Re: BDP-1 questions I can't find the answer to
« Reply #4 on: 26 Nov 2012, 07:35 pm »
NO
NO
Does not matter
AIFF is just fine
Leave this to the MAC guys
Cords do not matter - I just copy the files to the backup using my main computer.
NO limit
skunark
« Reply #5 on: 27 Nov 2012, 06:59 am »
I would review this on the best way to backup and synchronize the music for Macs (and for PCs)
http://www.audiocircle.com/index.php?topic=102438.msg1038459#msg1038459
You can do playlists for the MPD from iTunes, but it's not an easy task but you through mPad and mPod, you can select to play all songs in a given genre.
terrycym
« Reply #6 on: 27 Nov 2012, 09:13 am »
I use Microsoft SyncToy to back up my hard disks
speltz
« Reply #7 on: 2 Dec 2012, 01:28 pm »
I think it's a good idea to consider the speed of the thumb drive. If you have a thousand songs on a slow thumb drive, it will take a long time to load when you boot up the BDP-1.
I also found there was some improvement in sound quality when I switched to a faster thumb drive, although I haven't seen anyone else make the same claim.
I later purchased a solid state USB flash drive. They're rather expensive, but they are silent (no moving parts), very fast, and the one I bought works just fine plugged into the back of the BDP-1.
