0 Members and 1 Guest are viewing this topic. Read 12703 times.
If the above statement is true, than there is no way for us to reproduce audible low bass frequencies in our homes. Our speakers cannot handle the power levels required and the power amp doesn't exist that has enough power for the job. Yet somehow bass frequencies are reproduced in many listening rooms with readily available subwoofers and power amps. Scotty
Fred you are perfectly setup to test the effectiveness of a second sub in the main rig. Take the sub from the HT setup and plunk it down against the back wall of your listening room. Hook it up with what ever length is required of cheap AV interconnects you need to get it up and running. Operate it out of phase with the front sub to reduce the magnitude of the standing waves in the room. There should be some kind audible improvement in the quality of the bass as well as a noticeable gain in the three dimensional qualities of your systems imaging. The rear sub should operated at level considerably lower than the front sub. All you are trying to do is cancel out the bass energy remaining in the room after transmission and absorptive losses through the floor and walls has occurred. Ideally you shouldn't even notice that the sub is operating unless you are right on top of it. If it is properly canceling out the standing waves in the room you can turn it off in the middle of a song and watch the soundstage collapse towards the front wall of the room and hear the bass get lumpy and or muddy.Scotty
Yes, he's a Maine Coon.Scotty
Maine Coon's are special....now back to normal broadcasting....Jim
