0 Members and 1 Guest are viewing this topic. Read 12740 times.
Just to be clear, the Bass Integration Guide that I linked is written by Paul Spencer
I'd say yes, if you use measurement gear. I mean sweeps, not RTA. Otherwise, it's just guesswork and you may or may not get a good result.Or put it this way, if you measure, you'll have the best chance you have of getting a good result.This is a good guide to what you need to measure.
So for our ears to hear 20Hz as loud as 3.5KHz, the amps, including the power subs all add together, have to produce SPL 1,000,000 - 10,000,000 times loudness than 3.5KHz!!.
Does anybody see a problem with this statement?If the above statement is true, than there is no way for us to reproduce audible low bass frequencies in our homes. Our speakers cannot handle the power levels required and the power amp doesn't exist that has enough power for the job. Yet somehow bass frequencies are reproduced in many listening rooms with readily available subwoofers and power amps. Isn't it amazing.Scotty
