Can ONE audio subwoofer be added to stereo speakers and still sound great?
0 Members and 1 Guest are viewing this topic. Read 12701 times.
timind
  • permanent vacation
My experience with one sub is that it (and the mains) sound best when the sub is placed exactly between them, and a little back. Of course, YMMV.
Concur with this. Although, gotta say I never really did a lot of experimenting.
Wayner
I have found that if one sub is to be used, it should be downward firing. This is another level of defense, in detecting position of the lone sub. I have also found that placing a sub exactly in between the main speakers is not a good place, as it creates a pressure ridge that disturbs the imaging, at least with my Martin Logans.
That same pressure ridge can be had with older style, vintage speakers that have mid-range or tweeters offset from the woofer. The cure is to simply remember to place the mid-range/ and or tweeters to the inside.
With the down firing sub placed on the outside, it is now possible to work it around the nearest corner, as it too is an amplifier, as each surface (floor, rear wall, side wall) can add 6db of gain (naturally) to the subs output and also help diffuse the apparent location. Now the sub is probably already on the floor, so there is one unit of gain there, moving it closer to the rear wall, will increase output again, and then sliding it towards the corner will result in another increase in bass output.
I have also concluded to myself anyway, that overlapping cross-overs really muddies up the low end and makes the system bass heavy (unless you love bass). I tell friends to remember that subs are really just a "one note wonder", as they barely cover a couple of octaves (40-80-160). Our ears sense of pitch is very insensitive to such low frequencies, but this is the region where the sense of "power" begins.
My 2 cents
W
Mr645
I have always gotten great results when full range speakers and a sub for low end reinforcement.  I have never been really pleased with bookshefl speakers that reply on a single sub for all of the low end.  Not to say it can;t be done, but my limited experience I prefer large, full range speakers when possible
doug s.
  • makin' music
I recommend girlfriends.
i concur.  but, it's hard to get around the poor waf.   8)
doug s.
Freo-1
One subwoofer can work just fine, and provide the overall presentation with a more natural and lifelike rendering of the music.  For my audio only system, adding a Genesis 928 subwoofer (a servo unit with 2 12” firing drivers) provided a significant improvement to the overall presentation (especially with classical music).  The additional bottom end improves the music overall, and seems to tame some of variations with midrange and treble playback.  It really seems to make vocals seem more lifelike as well.  It did take some trial and error to get the placement and gain set correctly.  Wound up placing the sub to the right and behind the main speakers (Cary Silver Oak Model Ones).
Down the track, would like to get a pair of the Rythmik servos, as I agree two would be better than one.  Now, having said that, I find that the one subwoofer that I’m currently using works much better than no sub at all.
Regarding the full range speaker, Legacy Signature III’s have three 10” drivers, one in front, one down firing, and one in the rear.  The bass from that speaker is outstanding, very natural and deep, not at all boxy.
