Thanks KevinI was told if I wanted to try 0.75 ohms, I would need to use 2, 1.5 ohm resisitors in "parallel". Does that mean attaching both 1.5 ohms end to end and then inserting or just insert both into positive and negative separetely?Confused
When I buy resistors I like Dale,http://www.vishay.com/
The Dueland resistors are just simple graphite rods with silver lead-out wires. (Low inductance result.)
The Dueland resistors are just simple graphite rods with silver lead-out wires. (Low inductance result.)You can make your own for much less cost.....if so inclined. http://www.troelsgravesen.dk/graphite.htmBut actually, resistor inductance might be considered an advantage in some circumstances/environments.Cheers,Dave.
Hopefully we can get some humor from this."The #1 leads are a bit brittle sounding and the #2 is a little dark. But used in parallel they compliment each other and sound just right."
That isn't humor these days, more like starting a business.
That's great. I have an idea for a speaker wire line that is pretty devious. If I can only convince myself that it is not only ethical but brilliant as a concept then I might get the gumption up to do something with it. Hypnosis perhaps? Why oh why did I ever decide that I want to be morally upright? That was dumb.
