Re-entry with VPI Classic 1
0 Members and 1 Guest are viewing this topic. Read 43852 times.
jtwrace
    • TIPP YouTube Channel
Re: Re-entry with VPI Classic 1
« Reply #60 on: 20 May 2012, 01:19 pm »
You're gonna love it :thumb:
Sure do hope so!
:drool:
Minn Mark
« Reply #61 on: 21 May 2012, 02:58 pm »
+1 on the Zesto. That is one great looking unit.
Any posters out there try or are using the Parasound JC phono ($2350?) with a Classic I? Have been considering that one for my Classic I, though I am currently using Sumiko Blackbird. A true LOMC may benefit more.
Thanks. Enjoy the Zesto !
M
TONEPUB
« Reply #62 on: 21 May 2012, 03:24 pm »
The Parasound JC1 is outstanding.  Works well with the Blackbird and the Denon 103 as well.
Great phono stage at the price point.
Indiansprings
« Reply #63 on: 25 May 2012, 09:37 pm »
Error on my part :icon_surprised:
jtwrace
« Reply #64 on: 6 Jun 2012, 10:11 pm »
I've been informed that my Classic 1 arrives next week.  Finally!
TONEPUB
« Reply #65 on: 6 Jun 2012, 11:00 pm »
That sounds like excellent news!
Enjoy!
Waynefi
« Reply #66 on: 10 Jun 2012, 05:33 am »
Good luck, I am sure you will enjoy it. At a weak moment I sold my first one but just recently, came to my senses and acquired another.
jtwrace
« Reply #67 on: 10 Jun 2012, 11:03 pm »
Thanks.   :thumb:
jtwrace
« Reply #68 on: 21 Jun 2012, 03:21 pm »
Finally my Classic 1 has arrived.  It was delivered via UPS today and is in the back of my car...
woodsyi
« Reply #69 on: 21 Jun 2012, 06:08 pm »
Now you can forget going to sleep early and start the analog adventure.  Hope everything goes well but if you start hearing some hum, don't worry.  It's like a rite of passage for LOMC.  You will work it out.  But then Zesto has all that tweaks with grounds and stuff to "eliminate" hums.  :thumb:  Enjoy the sound and the process!  Phono cable makes more difference than IC with digital.  I prefer using balanced input into phonostage (like you have on Zesto) but I don't know if you can do that with the Classic.
I liked Zesto.  If I didn't already have a tube phono stage I really like and wasn't picking up a Soundsmith Strainguage at the show, I would have been far more into it.  I promised to go back and chat with George but couldn't make it.
You say you are set with cart but that will change in time.   :wink:  If you want to try a Koetsu, give me a holler.  I have a couple of spare Rosewoods lying around.  It could be a good match for the Zesto.  Koetsu and its bloom is an addictive sound if you are one of those who hear the "magic."
« Last Edit: 21 Jun 2012, 07:57 pm by woodsyi »
Berndt
« Reply #70 on: 21 Jun 2012, 06:20 pm »
Leave it to Rim to help you slide the Koetsu needle (sic) in...
Sonny
« Reply #71 on: 21 Jun 2012, 06:22 pm »
Yes, I/C make a difference...indeed...
Also, VPI does make an XLR Junction box...you can order it from them
T
TomS
« Reply #72 on: 21 Jun 2012, 07:31 pm »
Or with TonePub's Titan  :drool:
http://www.audiocircle.com/index.php?topic=107414.0
Never mind that it costs more than the table and would buy a LOT of shoes for someone :o
My Zesto is quiet with the MC transformer built in, but it takes a bit of cable dressing and trial and error on the grounds. Once the music starts I don't notice what little hum there is left (at high volume), as it sounds really good :thumb:
jtwrace
« Reply #73 on: 21 Jun 2012, 07:35 pm »
Thanks for the tips and my no hum fingers are crossed.
I'm still amazed at the VPI phone hours.  Tues-Thursday 12-5   :o
roscoeiii
« Reply #74 on: 21 Jun 2012, 07:40 pm »
They are very helpful when you reach them. With my luck, I received a HW-16 RCM I bought on eBay after 5 pm EST on a Thursday, and then they were closed the whole next week for the Newport Show. Thankfully the eBay seller was a good and patient guy who ended up refunding me my money, while keeping the broken machine (which lemme tell you is no longer broken, thanks to a new turntable motor!).
jtwrace
« Reply #75 on: 21 Jun 2012, 07:43 pm »
Yes, they have been great once on the phone...
vortrex
« Reply #76 on: 21 Jun 2012, 08:08 pm »
and don't forget to mute or lower your volume when turning off the table to avoid the VPI "pop".
orientalexpress
« Reply #77 on: 21 Jun 2012, 08:27 pm »
Jason
Welcome to the Darkside  :thumb:
lapsan
jtwrace
« Reply #78 on: 22 Jun 2012, 11:33 pm »
Thanks.  I had to try it and see if it did it and it didn't.  Actually dead silent.  Call it lucky but it made no noise.   :dunno:
Jason
lapsan
Thanks!   :thumb:
jtwrace
« Reply #79 on: 22 Jun 2012, 11:36 pm »
The VPI Classic arrived yesterday and I just finally got a chance to get it all setup and running.  Dead silent with the Zesto Andros too.  I was actually thinking it wasn't working as it was so quiet.  Lucky!!!!
Sounds pretty darn good but I need to experiment with cart loading on the Zesto and I REALLY need a RCM now.  Guess that will be next.   :o
