0 Members and 2 Guests are viewing this topic. Read 27026 times.
<<snip>>If I may speak on behalf of the ridiculously expensive for a moment, may I proclaim that I adore build quality? My experience with a wide range of amps confirms Josh's statement about the sonic differences between well-engineered amplifiers – not much. I was shocked at how much the VAC sounds like the Pass, (tube to solid state) but also at how close the two Pass amps are to one another, as well as how similar they sound to an Acurus and a Parasound amp I have. It's a hell of a lot of money for subtle improvements, but the build quality is a different matter – even the Pass amps fall short of the VAC in that metric.To make a sweeping comment which implies that one must spend huge sums of money for an amplifier to very satisfactorily drive any pair of Maggies is ludicrous, but it may be that the last little bit of refinement does cost pretty dearly. My system has never sounded better than it does right now.
I don't think the QR bass-mid would force series crossover use.....or vice versa. Previous (non-QR) speakers used a series crossover, and current QR (tweeter-only) speakers use a parallel crossover. However, the series crossover does prevent bi-wiring, passive bi-amping, and other types of fiddling that (maybe) Magnepan was uncomfortable with.Contrary to popular belief, series crossovers have no inherent "magic" or any other qualities that allow the laws of physics to be breached. A parallel crossover (configured equally) will create the exact same tonal balance as a series crossover.Nonetheless, it would still be interesting to take a look at the series schematics.Cheers,Dave.
When you start talking costs of support equipment for Maggies, the topic can get extremely nebulous and muddled. Much subjective evaluation comes into play and that (by definition) renders most opinions meaningless.Cheers,Dave.
This is not meant to be argumentative, but what do you consider "huge sums of money"?
I think "most" and "meaningless" are harsh words here.
Oh, I quite agree with your assessment that the VAC cost a huge sum of money (feel the same way about the Pass). Actually, even used, at less than half of new retail, I think it was a huge sum of money. I can also assure you that it was not necessary to spend that kind of money for the satisfaction I have - I was, after all, just as satisfied before buying the valve amp. I just wanted to give tubes a try and I had some money that I didn't mind spending. It's all part of my mid-life crisis! I bought a convertible (but its top has to be removed (and left behind )) sports car too. Isn't that what a guy in his 50s is supposed to do?What might have gotten lost in my previous post is that, without a direct comparison to..., I could be quite satisfied with a number of different reasonably priced amps driving my 3.7s - still could (though, it would take some readjustment). I tried lots of amps with the 3.6s (only experiment towards that end with the 3.7s was the switch to valves) and several sounded practically indistinguishable. The biggest surprise I got was a Bel Canto - that little ICE amp sounded very good and had plenty of swing. I hadn't heard a high-efficiency design in ages; I thought the last one I heard was awful. My expectations were pretty low. I was wrong. Heck, there are lots of amps with which I could be very happy, but I think I'll keep the one I'm using right now.
I agree about the speakers, but I would add that once you have settled upon your speakers (especially maggies) finding an amp that suits you (and your finances) isn't easy. I have tried a number of amps at home and can attest that they sound different. Not as different as various speakers, but different enough to warrant careful selection. These maggies (while not a difficult load as the old Logan CLS) can make an unsuitable amp sound pretty bad when stressed. Also there are a number of amps that just don't like the 4 ohm load.
Maybe you could ask Wendell, but do you know what the Magnepan policy is for making schematics available to the public? It would be interesting to take a look at the new schematics for the 1.7, 3.7, etc. I haven't seen anything anywhere.
Dave, if my understanding of the meaningful benefit inherent in a series topology is correct, it's essentially wasted on Maggies as the impedance of their drivers don't vary radically with frequency. I suspect 'permitted' may be more appropriate than 'forced', but that's just a guess. Regardless, the 3.7 has a much simpler XO than the 3.6, which I think is good (if one is going to keep the speaker-level, passive, that is).
Johsh,I don't know if you'd get the same holographic effect with a powerhouse pro amp/tube combo as you'd get with just big tube amps alone.Not pro gear but SteveK went from biamping with 4 VTLs to Class D amps (I believe) and gained with lower costs and noise floor but lost ground with the 3D sound. That's paraphrasing from memory so perhaps he'll chime in.The alarm still goes off at 5:30 AM so enjoy your evening.
Most folks don't think of this but, Maggies by their inherent nature already create a crossover between drivers (a mechanical one) before anything electrical (in the crossover) is even hooked up. You can easily see this by driving one transducer and monitoring the other with an oscilloscope or suitable meter. (Obviously I'm not talking about true ribbons here....those are separate transducers.)This is a form of "built-in" IM distortion. Maybe a good thing....maybe bad.
