0 Members and 1 Guest are viewing this topic. Read 26989 times.
Has anyone compared the HiFi Tuning Supreme to Furutech?I am currently using Cardas tweeter (15 AWG) and midrange (11.5 AWG) jumpers, anything "better" out there?
What type of speaker wire do you have?
AudioTruth (AQ) Argent
I don't know how expensive they are, but if you can get AQ to make some jumpers, this may work better. I also note that AQ sells jumpers.I was once told to use the same wire for jumpers as your speaker wires. This has worked for me but YMMV.Someone on Asylum speculated that using the same wiring that Magnepan uses internally may be a good idea.
I have heard that the tweeters require less current than the midrange and tend to work better with smaller wires. The Argent ($1055/8ft pair in the late nineties) is a bit too stiff and it is also discontinued.I haven´t got a clue what wire Magnepan uses internally, anyone knows?
The real issue in speaker cables is impedance. While tweeters probably do require less current since there's less energy in that portion of the audio spectrum, a larger cable shouldn't do any harm and an undersized one would reduce woofer damping. Some do like using magwire for their speaker cables, but if there's a theoretical reason why that should sound better rather than worse I haven't heard it. Maybe they get more bass because they reduce woofer damping.
My personal opinion is that the fuses are no big deal.
Waz, er, Kevin, I have to disagree. I haven't tried the Furutech fuses, but HiFi Tuning fuses made a substantial difference in my Maggies and some system components. The benefits weren't noticeable everywhere, but where they did it was immediately apparent. I can dig out my review of them at that other board.Regards,Steve
Give the AMR fuses a try. They're cheaper and you get 3 in a pack for less than the price of one furutech.
Any downsides that you identify to go along with the benefits?
