0 Members and 1 Guest are viewing this topic. Read 17872 times.
Ske,Tell me more about this project, please.
Hey Jim,I'm looking for a fresh start in a pleasant place as well.
Hey Steve,I can only get the 1.7s 30" from the front wall, and the edge is only about a foot from the side wall. So I use the stock resistors and Rear Wave Attenuators. But there's no escaping the fact that the rear wave is bouncing back at me too soon and direct, and it adds a harsh edge to music.Being in school and, I'm on a tight budget, the poly-cylindrical is a great option. It will scatter the rear wave, as well as absorb some as a resonating trap. I've done alot of looking around on the web, and there doesn't seem to be a consensus on specific designs except the larger and deeper it is, the lower the frequencies it can absorb.I've seen them open ended and enclosed. You can simply bend a piece of masonite between a frame, or nail the masonite to curved pieces of plywood to make the curve.I'm leaning towards bending a sample piece of masonite, tracing the curve, and cutting that out of plywood to form either end. But still catch the edges against a frame on the sides, use caulking all around, fill it with insulation, and attach masonite to the back. I may or may not add a thin layer of foam to the outside. I'll try it with and without…
