New lower priced Bryston ‘IS Series’ BIT Product
0 Members and 1 Guest are viewing this topic. Read 38382 times.
  • The Demo is Everything!
    • http://www.bryston.com
MEMO: To All Bryston North American Dealers
SUBJECT: New ‘IS Series’ BIT Products
Premium Power Conditioning at Entry Level Prices
Bryston is pleased to introduce the new BIT ‘IS Series’ of premium power conditioning at entry level prices.
Like all Bryston BIT products, IS Series models provides true isolation from the external power grid, noise filtration using toroidal isolation transformers featuring proprietary NBT technology and high levels instantaneous (peak) current on demand.
To achieve the lower price point, the ‘IS Series’ does not include ‘series mode surge suppression’, which remains available in other Bryston BIT models.
There is no compromise in the IS series – it performs like all Bryston BIT conditioners, offering sparkling performance with noticeable increase in dynamic range, imaging, bass response, depth in audio, and increased definition in video.
There are 3 models available: 5 Amp, 15 Amp, and 20 Amp, - 120 Volt/60Hz
Specifications:
•   Input Voltage and Frequency: 120VAC Range ± 10% (57-63)Hz
•   Input Current Limiting: N/A
•   Input (inlet) connector Rear panel: 15A inlet (20A on IS-20)
•   Output voltage: 120V AC
•   Output connector: Medical Grade Duplex 15A  Outlets
•   Surge Suppression: Not supplied
•   Noise Reduction: Performs as low pass filter, attenuating noise from 2kHz to 1mHz, with attenuation of 12 db/decade to 500 kHz.
SoundGame
Re: New lower priced Bryston ‘IS Series’ BIT Product
« Reply #1 on: 25 Jan 2012, 08:23 pm »
You've tweaked my ears with this new product.  Could you share the Canadian and U.S. list prices for all models?
In addition, with a 4B-SST2, which would be the recommended model.  I have noted that the 4B-SST2 manual states that the actual current draw into 4 ohms at maximum output is 2100 watts, which actually equates to 17.5 Amps @ 120 volts, which is what is confusing me.
« Reply #2 on: 25 Jan 2012, 08:53 pm »
IS Series Single Phase Input  -  120V
BIT-IS 5 B 17   IS Series Single 5 Amps/120V/60Hz        1,095.00
BIT-IS 5 S 17
BIT-IS 15 B 17   IS Series Single 15 Amps/120V/60Hz     1,495.00
BIT-IS 15 S 17
BIT-IS 20 B 17   IS Series Single 20 Amps/120V/60Hz    2,395.00
That power draw is not continuous.  I usually recommend a minimum of 10 amp Torus unit with a 4B SST2
Alpha10
« Reply #3 on: 25 Jan 2012, 09:00 pm »
James, is there any chance of a 240Volt version for the UK, as we are not getting the full BIT?
Cheers
« Reply #4 on: 25 Jan 2012, 09:03 pm »
Cheers
Hi - we are looking at offering the BIT in 220 and 240 volt versions - so far there has not been much demand outside North America.
james
skunark
« Reply #5 on: 25 Jan 2012, 09:03 pm »
Are 19" faceplates available yet?
« Reply #6 on: 25 Jan 2012, 09:08 pm »
Yes I think the drawings are in so we are just waiting for samples.  They are C-Series 19 so they are not rackmount.
james
SoundGame
« Reply #7 on: 25 Jan 2012, 09:16 pm »
BIT-IS 5 S 17
BIT-IS 15 S 17
Thanks James!  Nice to see you guys finding creative ways to make things more affordable, which is a win-win scenario.  Cheers!
John Casler
« Reply #8 on: 25 Jan 2012, 10:32 pm »
Great, have a couple customers looking at Power Conditioning :thumb:
Available when?
Alpha10
« Reply #9 on: 26 Jan 2012, 07:30 am »
james
Morning James, that is good news, I think it is one of those "if you build it, they will come" type products, there has definitely been chat about them on the UK bryston forum  :thumb:
Cheers
Vipers
« Reply #10 on: 26 Jan 2012, 04:37 pm »
Cheers
Alpha is right, you could definately put my name on one James when they are available to the UK market :)
alexone
« Reply #11 on: 26 Jan 2012, 06:34 pm »
james
...probably the people on the other side of the pond don't know about it??
just a thought...
al.
Heckler75
« Reply #12 on: 29 Jan 2012, 05:17 pm »
BIT-IS 5 S 17
BIT-IS 15 S 17
Hi James,
are  these   new "IS"  series  single 120/60  (BIT-IS  15 B 17)  available now , or will they come out soon.
another  winning product from Bryston  :thumb:
« Reply #13 on: 29 Jan 2012, 07:05 pm »
Hi James,
Hi
Available now :thumb:
James
Heckler75
« Reply #14 on: 29 Jan 2012, 07:40 pm »
Hi
James
awesome :green:
the BIT-15 "IS" series, still uses the same  Bryston faceplate , and is  same  size as  standard  BIT-15.
« Reply #15 on: 29 Jan 2012, 07:50 pm »
awesome :green:
Correct sir.
James
VOLKS
« Reply #16 on: 29 Jan 2012, 07:54 pm »
James......the "Bit" series offers the "series mode surge suppression" ....i have a good idea,but what exactly does this offer over the new "IS" series?
« Reply #17 on: 29 Jan 2012, 07:58 pm »
It protects you against surges and electrical spikes on the power line. Some areas have serious issues with power spikes and many areas with lightning affecting the power grid.
James
SHV
« Reply #18 on: 29 Jan 2012, 08:31 pm »
What duration in a transient fall in power will a BIT 20 buffer?  I live in an area where Summer lighting can be "fierce" and can be associated with rapid transients in power.
« Reply #19 on: 29 Jan 2012, 08:54 pm »
What duration in a transient fall in power will a BIT 20 buffer?  I live in an area where Summer lighting can be "fierce" and can be assoDciated with rapid transients in power.
Hi Steve
I would have to get that from engineering - what I can say is I have had people call me and tell me that they had a lightening strike and all that survived were the units attached to the Torus.
James
