0 Members and 1 Guest are viewing this topic. Read 38093 times.
Yes the 240 volt 50Hz BIT versions are BIT-4, BIT-8 and BIT-16 and are the maximum AMP ratings.BIT 8 would be the same as our BIT15james
Hi James, thanks for your quick reply on all my questions.I just placed and order for UK version BIT 16 silver with 17" faceplate. You mentioned that the International versions only has BIT engraved in the front faceplate and not 16. Is there a reason for it and how can one tell if its 4, 8, or 16?? I love the green switch
Hi James,Are you doing a mainland Europe version of the BIT? More to the point, can I order one in Switzerland?RegardsRon
Hi Ron,Yes just get in touch with the Bryston distributor.james
I'm guessing I need a bit 20. The 7's are connected to a dedicated 20 amp line.2 7/BSST2BDA-1BDP-1BDC-1Bat 32SEany thoughts?
James,I ordered my Bit 20 today from GTT Audio in New Jersey. Looking forward to having protection and a constant 120v in the summer months. We are notorious for having brown outs and low voltage. Wondering if I'll hear a difference in sound.BJ
I don't believe the BIT 20 will help with brown outs, as I don't see AVR capabilities. I purchased a Torus AVR to solve my power supply issues [but returned it due to issues].
hi, Patrick!...what issues did you have?thanks,al.
Thanks for the listerature you sent via e-mail distribution list, James. For international models, are you offering the US-style, three prong, 220V-240V, receptacles as an option (the type that TorusPower won't install for their int'l models)?
