New lower priced Bryston ‘IS Series’ BIT Product
0 Members and 1 Guest are viewing this topic. Read 37366 times.
  • The Demo is Everything!
    • http://www.bryston.com
Re: New lower priced Bryston ‘IS Series’ BIT Product
« Reply #40 on: 27 Feb 2012, 05:07 pm »
From Plitron:
Hi James,
IS stands for Isolation.
Matt
Alpha10
« Reply #41 on: 27 Feb 2012, 06:59 pm »
Really excellent news, thank you James.
Cheers
Hi,
I believe it will be all models.
james
Alpha10
« Reply #42 on: 28 Mar 2012, 06:36 pm »
Hi,
james
Hi James, any update on when the BIT products are going to be available in Europe/UK?
Cheers
« Reply #43 on: 28 Mar 2012, 06:40 pm »
Cheers
Yes we are in the process of taking orders from our distributors.
james
Alpha10
« Reply #44 on: 28 Mar 2012, 06:54 pm »
james
Brilliant news, thank you.
Which BIT would you recommend for me (240V) to power SP3/BDA/BDP/4BSST2 + Oppo Blu-ray and Sat-receiver?
Cheers
« Reply #45 on: 28 Mar 2012, 06:57 pm »
Cheers
BIT 8 or BIT 16.
james
Alpha10
« Reply #46 on: 28 Mar 2012, 07:16 pm »
BIT 8 or BIT 16.
james
Thank you very much.
werd
« Reply #47 on: 28 Mar 2012, 09:16 pm »
Cheers
Go for the biggest bit you can afford. Dual phase if possible too.
SHV
« Reply #48 on: 28 Mar 2012, 11:06 pm »
That is what I wanted but that option isn't available.  I finally opted for biggest (most amps).
Vipers
« Reply #49 on: 29 Mar 2012, 04:27 pm »
BIT 8 or BIT 16.
james
Hi James,
I'm really interested in adding one of your conditioners to my system shortly, going on what you said above, unless I've missed something, I take it for the UK are we getting different model numbers compared to the US?
I've got a very similar system to Alpha with 7B's instead of a 4B and a BCD-1 + a TT, I take it as long as the budget will stretch I will be best to go with the UK equivilent of the BIT20?
« Reply #50 on: 29 Mar 2012, 04:52 pm »
Hi James,
Yes the 240 volt 50Hz BIT versions are BIT-4, BIT-8 and BIT-16 and are the maximum AMP ratings.
BIT 8 would be the same as our BIT15
james
alexone
« Reply #51 on: 29 Mar 2012, 07:06 pm »
James,
how many outlets has the BIT 8 (240V 50Hz)? 10 like the "overseas" BIT15 would be cool...
and i hope the "IS" versions are available, too :D
al.
Vipers
« Reply #52 on: 29 Mar 2012, 07:56 pm »
james
Thanks James, I take it PMC have all the info regarding specs and prices?
If so I'll make a call tomorrow to see what I can find out :)
« Reply #53 on: 29 Mar 2012, 08:03 pm »
James,
al.
Sorry with those big British plugs only 5.
« Reply #54 on: 29 Mar 2012, 08:04 pm »
James,
al.
'IS' only BIT 4 and BIT 8 - no BIT 16
Vipers
« Reply #55 on: 29 Mar 2012, 09:42 pm »
So the next question is I guess, how many outlets will the BIT-16 have? can that stretch to 10 with the bigger chassis?
« Reply #56 on: 29 Mar 2012, 09:46 pm »
Not sure we can but I will check.
james
Vipers
« Reply #57 on: 29 Mar 2012, 10:04 pm »
james
Here's hoping, otherwise I'd have to end up having 2 :roll:
alexone
« Reply #58 on: 29 Mar 2012, 10:30 pm »
James,
is it ok -technically speaking- if some kind of these multiple inputs are used with a BIT (IS) unit in order to have more inputs :scratch:
al.
« Reply #59 on: 29 Mar 2012, 11:07 pm »
From a protection and noise floor point it would work but from an instantaneous current draw it would not.
James
