Narrow Rca plugs
0 Members and 1 Guest are viewing this topic. Read 2023 times.
kbuzz3
Narrow Rca plugs
« on: 25 Jan 2012, 03:54 am »
Anyone have any suggestions for high quality jacks that interface nicely with the tight vintage jack spacing?
Sonny
TQdB
Re: Narrow Rca plugs
« Reply #2 on: 25 Jan 2012, 07:47 am »
+1  :)
Those are the exact part I was going to suggest. You'd have to go to Eichmann Bullets to -hear- anything better. They're nickle plated but that's not a big deal at line levels and the guts are a copper alloy. Depending on how much EMI you have, wire those up with a twisted pair or signal tape style http://www.soundstage.com/synergize/synergize021998.htm made from some 28 gauge magnet wire and enjoy them forever.
Wayner
« Reply #3 on: 25 Jan 2012, 12:57 pm »
The spacing on audio in and out pairs on my Revox has a center to center spacing of about 7/16" or about 11mm. That means the connector can't be any bigger in diameter then 11mm. 10mm would be better to give some space in between.....
Wayner
gcos
« Reply #4 on: 26 Jan 2012, 10:33 pm »
anyone know of an adapter which will allow you to use your normal interconnects?
Sonny
« Reply #5 on: 26 Jan 2012, 10:49 pm »
Just solder two wires from your connector to the jack!   :D
