0 Members and 1 Guest are viewing this topic. Read 21946 times.
... So I cannot use a preamplifier by itself, but the integrated could serve as a preamp for the selector stage if it has a preamp out?
I have a funny feeling that things have not really been cleared up for you. Why would you want to buy an integrated amplifier just to use it as a pre amp? Maybe you should explain a little bit more what you are trying to achieve so you can get better advice.There is something else that has not been mentioned to you. Many (not all) integrated amplifiers are nothing more than a sensitive power amplifier hooked up to a passive input selector and volume control. There is no gain or "pre-amp" involved so the "line out" may be subject to the same issues that a passive volume control center has. This may or may not work well for you.
I was just making sure I understood how things 'could' be setup, ie, if I were to get an integrated, then wanted to get a separate power amp later down the line, I could do that, using the integrated as the preamp as long as the integrated had a preamp out - correct?
