0 Members and 1 Guest are viewing this topic. Read 83176 times.
Did you see the pictures of JohnK's scale model?http://www.diyaudio.com/forums/multi-way/195734-nelson-pass-slot-loaded-open-baffle-project-20.html#post2700050
I am sure Nelson provided all of the details he had on hand. He probably designed the slot loaded OB based on his vast knowledge, experiences, and inherent understanding of loudspeaker design. Then he built it and listened. Maybe he tweaked later, I don't know.So when it comes to building a different design using different drivers you are starting at square one, you have to do all the work yourself. Nobody has prior knowledge to share. If it were my project I would write the software required to do a trade-off study to optimize the geometry and driver choice, then I would build and test. But that is just my method.So you are left blazing a new trail, getting frustrated that people are not helping seems pointless since they probably have nothing to offer. You are the design leader. You can either do the engineering work or drop back and go in a different direction, your call.
But to be completely ignored is just wrong I think.
The pics of the slot loaded open baffle are very vague. There's no well lit, close up shots of the slot. All you see is a black slot on a light bare baffle. No details to speak of.
The only thing that concerns me there is the effects of the resonant frequency of the rear chamber which would be much larger than the slot.
From what I can tell, this slot loaded design is really nothing more than a modified ripole with an open back.
Oh hang on, I'd claim that it's really nothing more than my design but with the woofers moved closer together: In the end, you just have to build something and try it.
From what I've read, it's simply the ratio of the slot area to Sd that matters. Nelson used a ratio of 1:3, I think I saw someone say 40%. I don't think I've seen anyone comment that it matters how the slot area is arrived at, I'd be curious to know if it did matter.
