0 Members and 1 Guest are viewing this topic. Read 83176 times.
I have the Tang Band W8-1808/Alpha H-frames and WBL Betsy's/Alphas powered by SET/SS amps and while the Betsys are fun and enjoyable the TB's are in another league. I really like the looks of the Daytons and hope to try a pair. They are certainly priced more reasonably than the TB's.
I am in the process of gathering information, ideas and parts for Nelson Pass' slot loaded open baffle. I've already ordered a lot of twelve 8" Peerless India 12 ohm drivers. Now I'm looking for fullrange drivers for the top end.
Why don't you use what Nelson uses on top? (sorry if this was suggested already, I didn't notice it)
Can I ask? Have you owned any fullrange-driver speakers?
Is there a specific reason for going with a larger FR driver?
Because I want to be able to cross over as low as possible to get the most out of the fullrange drivers, and no crossover anomalies within the critical listening range. I'm shooting for roughly 150Hz crossover point.
That is not a function of driver size though. Most FR drivers 3" or larger will have no problems with a 150 Hz crossover. The low-frequency rollof is dominated by the baffle size, not the driver size. The driver size will have much more of an effect on sensitivity and peak output level (and to a lesser extent, power handling), at the cost of on- and off-axis FR smoothness. (Speaking in generalities.)I got the impression that you are concerned about high-frequency response, which is why I asked. Unless sensitivity and output level is a concern, I wonder if you should look at the current Mark Audio drivers.
What size baffle are you thinking of? You may want to try a couple of sims, as if the baffle is too small you will need to either move the crossover point up or "resort to EQ"
