0 Members and 1 Guest are viewing this topic. Read 83176 times.
I still haven't been able to gather anymore information on the slot design. Mr Pass is MIA as far as email is concerned
On a little bit happier note, the Alpair 10.2's are beautiful, very well made drivers. Even my girlfriend likes them! She's glad I chose the gold version.
Visit the thread on diyAudio. Likely all you need to know is there.Indeed they are. They actually aren't gold, but copper. Gold is an artifact from the 1st gen when you could actually get gold cones.dave
I do hope you don't plan on using that wire?I'd suggest something much skinner & solid core (CAT 5 strands work well). Then you can rid yourself of the clip connectors and solder directly to the terminals.dave
actual cone size of these drivers is more like 4 to 4.5", not 6"
Sounds promising
Not having read the whole thread, it may have been pointed out that you should be using Alp10.2 with some kind of High Pass filter above 200Hz for OB config. It's really easy to push the 10.2 into loading.I have Alp12 in OB and enjoying every minute of it. I also have 10.2 (a whole lot of them) for the Line Array build soon.
Another one with the whole "spoon fed" speech. You must have read the other thread...As I said in that thread..."I don't want to be "spoon fed". I would however like to have a little bit more information to go on before starting any cutting. There's virtually no info on the innards of the slot itself. If each pair of woofers are indeed in separate compartments, how tight are those compartments? Is it equivalent to having three ripoles stacked with their back sides totally open? Do those compartments terminate before the opening of the slot? And if so, how far from the opening?The pics of the slot loaded open baffle are very vague. There's no well lit, close up shots of the slot. All you see is a black slot on a light bare baffle. No details to speak of.All I really need are some details on the darn slot and I'd probably be willing to start on the building. But without knowing anything about the slot thus far, I refuse to go anywhere with this project."Also, I can't count how many times I've searched both the forums and Google about "slot ported open baffles" to only find the few threads on the two forums I belong to, and the Enjoy the Music article. There is not that much information out there, and whatever info IS out there is just the links to these forums that I've already seen and read.
Build some MJK H-frame Alphas for your Alpairs and be done with it.
