0 Members and 1 Guest are viewing this topic. Read 25854 times.
If a power tube fails catastrophically, shouldn't a fuse blow before a transformer melts? Sounds like the amp was not designed correctly to me.
Steve:While there has been improvement in QC, the metallurgy and inert gases will never be the same due to many factors. However, many of the modern amp, preamp designers are factoring into their designs modern tubes and in such instances, vintage tubes may not be advisable.I still see no advantage of running tube gear 24/7 and only downsides.Jim
...the OP has either sold his tube gear or figured it out for himself by now.
