0 Members and 1 Guest are viewing this topic. Read 25844 times.
Well never again for me. My amp using a Full music 211 went taking the trannies with it. if I was in the room when it occurred the trannies would not have melted. Just a bad tube. Only 15Hrs on the sucker. They were tested by the dealer. Measured pefectly. There is no way of telling when it will go. Thanks to Grant Fidelity and Consonance who stood by there products helped me big time in getting Humpty Dupty put back together again. I leaned my lesson the hard way. Never again. Now using either RCA or GE Mil spec 211s.
If a power tube fails catastrophically, shouldn't a fuse blow before a transformer melts? Sounds like the amp was not designed correctly to me.
Well, old timer, when you were in the military, you didn't have to pay for tubes!These days just leaving my ARC REF 5SE and REF Phono 2 SE on 24/7, with an anticipated life of about 5000 - 7000 hours on the tubes means, if I shut them off for the 12 hours a day I'm not using them, I double the tube life. And at a cost of about $500 per to retube it makes more financial sense than worrying if something is going to burst into flames.
6SN7's are pretty robust tubes... I've been told that some of the RCA and Sylvanias, went well over 50,000 hours. And sounded great to boot.I'll be curious to see how my ARC gear does with the 6h30's. They say 5000 hours, but when I had the CJ ACT2, it went almost 20,000 hours on the first set of tubes.Now, if I only had some of those 6CA7's from back in the 70's...
...I will agree with Doug S here, who stated that he would only remove expensive phono stage tubes in the event that you owned a pre with a built in phono stage...
I'll listen atleast 9-12 hours a day until I reach the 200 hour mark and typically listen 2-3 hours daily
which brings up another side issue - i won't even consider purchasing a piece of equipment if it costs a small fortune to re-tube it. i'm simply not interested. ymmv,doug s.
Is this just to burn in the tubes when new?
Yeah. I had found an Audio Research Sp-10 mk2 locally(at a used equipment stereo dealer!!) and paid only $600 cash plus some junk trade in stuff I got for free. It had not so great tubes, but worked. Welli just could not see paying a medium fortune for tubes to retube it.. So i ran into an ARC SP-15 and liked it better than the Sp-10. I wa able to sell the Sp-10 on Agon for enough to pay for it, and the Sp-15 And have a few hundred bucks left over.(And I STILL sold it for $800 below the market price.)Anyway, If i had collected piles of tubes back when they were just old surplus junk, I too would be a happy tube lover. As it is, i remember most of those NOS tubes costing an arm and a leg now, were dollar surplus at one time. and cringe.I have 4 items using tubes in my piles of stuff. Thank goodness they all use cheap to find tubes, and few of them too!
