0 Members and 1 Guest are viewing this topic. Read 25846 times.
you could probably run a tube preamp 24/7 if it is SS rectified but the types of tubes that i like to run in them are very rare and very expensive.that being the case it is not a very smart thing for me to do.to leave a tube power amp on 24/7 is very dangerous and if something goes wrong with no one around you could lose a transformer like Charles did or you could cause a fire
Hi.(1) Theoretically, tubes get lifespans. However, maybe my 50-year-old Dynaco phono-preamp & power amp both are lucky ducks as they are still kicking around bigtime like kids. The 50-year-old tubes inside sing like nightingales.(2) This is always a good practice to give the tubes some good rest by switching them off pending for next startup. I always switch them on a couple of hours before my music session to get the tube heaters working at their optimum temperatures.Save the good Earth as well as our wallet.c-J
As already aptly noted, tubes do have a lifespan, some more than others, then consider the heat and energy they consume while one, even at idle, and the fact that while the tubes may not go bad, other components can and will cause major damage to your gear and potentially start a fire. If one turns on their respective tube gear 22-30 minutes prior to musical enjoyment, the tubes will have heated up and all the capacitors will be fully charged. If I anticipate listening to music several different times, I might leave them on so there isn't that initial flash that does diminish the lifespan...however, most quality tube gear usually have a slow start circuit that does spare the tubes from this. Jim
There is no such thing as a safe electrical product. PERIOD.
When do you usually turn your tube amp or preamp on, and do you leave it on all day. With my SS stuff I don't think about it, but I'm betting tubes required more attention. Since tubes get pretty hot, my guess is that it's best just to let them run and turn them off at bedtime.Share your on/off routine. Thanks!
Sure there is. NO THERE IS NOT!
