0 Members and 1 Guest are viewing this topic. Read 25843 times.
Nice amps. Their sound will greatly improve after the first couple of day. My Samsons continued to improve up until around 500 hours. Not that they sound bad out of the box. They pleasantly blew away my previous amps cold out of the crate. Congrats and enjoy the ride!
I need to break in a TRL Samson solid state mono blocksI have a Doshi pre (8 tubes) and was considering running it 24/7 for about a weekwith my cd player set in repeat modehttp://doshiaudio.com/wp-content/uploads/2010/10/doshi_alaap_final.pdfTubes 2 mc, 2 mm and 4 main stage 12AX7 (ecc83), 12AT7 (ecc81) , 12BH7should I turn it off at all during this time instead?
I think your amps will break-in just fine without music running through them. You can shut off your CD player and preamp and leave your amps on if you like. Just turn them off before turning your preamp and sources on.
FWIW, Paul @ TRL recommends running music through them, 24/7.
I got a comfirmation from Paulplay music or fm static at any volumeUnit sounded poor out of the crate but much better this morningcan't wait for the first 40 hours
Paul said for the first 40 hoursto expedite the break in period
No way Jose. 24/7 is really not an advantage and dangerous. . The elements and dielectrics need to settle in. The most affective method we have tried so far is 5 hours on and 5 hours off until 100 hours is reached. A royal pain but worth the effort. All broken in and ready for prime time listening. Learned my lesson leaving amp unattended, 211 output blew and melted yes melted the wax in the output trannie. If you are not in the room do not leave your tubed amp on. Thanks to Grant Fidelity and Consonance for putting Humpty Dumpty back together again. charles
Hi Charles,Do you feel this way about solid state amps too?
i'd let it run 24/7. my line stage preamp, w/four 6922's, and a single 12ax7 used in the wolume pot circuit, has been run pretty-much 24/7 for >10 years.
This is what I run for a pre right now. No off switch. Its got a on/standby switch. Pulls 0.4 Amps at 120V all day long. Only pops up to 0.5A - 0.6A when turned on.
Hi.Assuming tubes can run forever & money is no issue to replace them, may I humbly suggest you to save energy to save our mother Earth?Amen!c-JPS: the Telefunken tubes in my tube phono-preamps are all 50-year-plus old, yet I'd treasure them by switching them off after my music session.
