Gateway Audio Society ("GAS") Member Map
0 Members and 1 Guest are viewing this topic. Read 24141 times.
Bob in St. Louis
Re: Gateway Audio Society ("GAS") Member Map
« Reply #40 on: 3 Dec 2011, 02:49 am »
Ahh....Thanks dude.
Tonight .... at home, it's time to chill out.
Tomorrow at work, I'll have time to play with the map.
Seems backwards, doesn't it?  :peek:
Thanks for spelling it out. I'll be back on the case tomorrow.  :thumb:
Bob
michaelhigh
« Reply #41 on: 3 Dec 2011, 06:27 am »
Bob, you have PM from me. Thanks.
Bob in St. Louis
« Reply #42 on: 3 Dec 2011, 06:27 pm »
Mike, PM received. I've added you to the lists.
Ok guys......You should have something in your email inbox from Google Maps.
If I did this right, you should be able to add your pins and comments, but NOT be able to adjust other peoples pins and comments.
Can somebody verify?
Bob
catastrofe
  • "That's what credit cards are for. . ."
« Reply #43 on: 3 Dec 2011, 07:08 pm »
I just moved Mitsuman to the middle of Lake Carlyle so I don't think it's working properly.   :lol:
thunderbrick
  • I'm just not right!
« Reply #44 on: 3 Dec 2011, 07:09 pm »
Moron, here.  How the hell do I put a "pin" on a location? :scratch:
Mitsuman
  • Diamond Tone Junkie
« Reply #45 on: 3 Dec 2011, 07:22 pm »
Ironic, because I'm actually from not too far from there. Used to fish at Carlyle Lake all the time as a kid.  :lol:
Bob in St. Louis
« Reply #46 on: 3 Dec 2011, 07:31 pm »
:scratch: Hmm.... Ok.... Um....Lemme mess with it some more.
I'll let you know when I change something.
Bob, no worries about your pin yet, Hang on a spell.
Bob
Bob in St. Louis
« Reply #47 on: 3 Dec 2011, 07:41 pm »
OK, can a guinea pig please try to move somebodies pin please?
KenSeger
  • Heavy and noisy, but beautiful
    • Ken's Plain Jane Website
« Reply #48 on: 3 Dec 2011, 08:09 pm »
Bringing up the map via the URL you emailed - it does bring up the map just fine, if you click on a pin and then More, the Move function is in light print and not enabled.  TA DA!  I don't see anyway to add a pin in this mode.
Ken
P.S. the map's name was Gateway Audio, now it is thunderbrick.
Bob in St. Louis
« Reply #49 on: 3 Dec 2011, 08:14 pm »
Hmm,....  :?
I'm thinking this map isn't going to work.
I can either give everybody access to change everything, or I allow viewing only.
That's useless.
I think I'll look at the map the Carolina guys are using. If we go that route, I'll delete all the info from the Google Map, just so there's not info hanging out there, ya know...
Thank you Ken for being the Guinea Pig there.
Bob
Bob in St. Louis
« Reply #50 on: 3 Dec 2011, 08:44 pm »
Still in the learning stages of this one too.  :roll: :duh: :lol:
http://www.mapservices.org/myguestmap/map/BobinStLouis
catastrofe
« Reply #51 on: 3 Dec 2011, 08:46 pm »
I just moved Mitsuman to Lake of the Ozarks, so it's still not working properly.  Just dragged and dropped.
electricbear
« Reply #52 on: 3 Dec 2011, 08:50 pm »
Just tried the new one. It was very easy to place. Did not try to move Bob though.
electricbear
« Reply #53 on: 3 Dec 2011, 08:50 pm »
Ok, it did not let me move Bob.
Bob in St. Louis
« Reply #54 on: 3 Dec 2011, 08:55 pm »
I'm not sure if I'm going to worry about that map anymore. There's too much open to the public.
Tim, Good. That helps. Thanks.
I think I'm finished for the day. If you folks want, you can populate the second map.....but at the risk something may go wrong and it all gets wiped out. So don't get too fancy with it.  :lol:
Bob
Bob in St. Louis
« Reply #55 on: 4 Dec 2011, 03:31 pm »
Just a reminder fellas......don't click on anything that has to do with my name that's related to pornography.  :shake:
Sorry about the emails guys.
Of the two PCs I'm using, I'll be formatting both harddrives, probably next weekend. I hope that fixes it, nothing else has.
Bob
Sarmck
« Reply #56 on: 4 Dec 2011, 03:49 pm »
Hope there is not a distance restriction to membership...   :thumb:
(Sort of the south west side of STL)
Ron
Bob in St. Louis
« Reply #57 on: 4 Dec 2011, 03:57 pm »
 :lol: No, you should be good Ron.
Tim is a bit towards the south east of STL.  :thumb:
Bob
electricbear
« Reply #58 on: 4 Dec 2011, 05:18 pm »
Quote from: Bob in St. Louis  8)link=topic=101116.msg1022003#msg1022003 date=1323014240
Bob
lets just say that I'm in a different time zone and at the moment it seems like an entirely different ecosystem . It's 75 here.
Bob in St. Louis
« Reply #59 on: 4 Dec 2011, 05:34 pm »
Yea, enjoy that. It's presently 42 and raining here.
Next weeks forecast is: We'll be lucky if we see 40 degrees, and they're calling for snow flurries on a few days.
Bob
