0 Members and 1 Guest are viewing this topic. Read 156290 times.
It will come up under a search for AD1865 on ebayhttp://cgi.ebay.com/DAC-AD1865-AD1865N-K-NOS-1-0-NOS-/320616005653?pt=LH_DefaultDomain_0&hash=item4aa6340015#ht_2469wt_1135
YesAre these the OS-cons you speak of? I found some on that auction site, which type are being used here?russellc
47uf vishay organic polymer caps from Digi-Key or mouser 10v or greater.OP equals oscon.
For transport I am using my computer with USB to teralink x2 spdif converter and USB isolator.
Well for kicks I swapped out the 4700uf Nichicon Gold Tunes from the AD1865 DAC and replaced them w/ some 15000uf and 18000uf caps. There was a noticeable improvement in sound quality.
Quick update on the raindrop AD1865 DAC: I was taking a look under the hood earlier this week, thinking I should add some more Oscons to the PS regulator area (which is recommended in Andrea's original design) and thought while I'm poking around, maybe I ought to just bypass the jfet output stage and just use 2 resistors by passed with a small value cap (.0068uf) for a passive I/V.
Would you say that the resistor and bypass-cap enhances the sound? I'm listenig to mine directly from the AD1865 chip with good results...
Thanks for all the great info! I just ordered one of these and want to start collecting upgrade parts. What is the voltage on those stock Nichicon Gold Tunes?
The Gold Tunes were probably 35v. They didn't come with the board though.
Nope, no resistor at all, connected the RCA's directly from the three (the middle acting as ground for both left and right channel) predrilled soldering points in the marked ring;The thing is, that it's loud. It is slightly louder than listening to my analog out from my Squeezebox Reciever...I don't thinkt there would be any problem adding a resistor to this, since it's so loud. Should I?Modifry: Yes, it's working now, but when listening thru the Tube I/V-stage, it gets all distorted, maybe because it's too loud signal to amp..?
You need the resistors!!! You can't just listen to it direct. The resistors are needed to convert the current to voltage (I/V). There are inputs for the resistors on either side of those outputs in front of the chip ~220-300 ohms is what most use. On the board it even says 220R.
Will do, but if I don't - what could happen?/M
Just saw you mentioned having the tube I/V stage. If you are using that you don't need the resistors then. What do you use after it? preamp? what's the gain of your amp?EDIT: your tube I/V has a high amplification factor (mu 70) more suited for TDA1541 chips and similar. Way more gain than you need, which would explain the distortion. I am able to get loud enough (for me) volumes with no gain at all.
I'm using a homemade tube amplifier, I use the Squeezebox to set the volume (digital volume control), not optimal but sleak. That could explain the distortion yes, damn I suck at theese things. Could I lower the amplification factor? Otherwise - who want's to buy a tweaked tube stage? My set:
