0 Members and 2 Guests are viewing this topic. Read 340851 times.
Looking good sir. What are the basic spects of Nelson Pass B-1 buffer?For those curious minds. .......and, is it possible to implement battery power supply into this DIY project?If so, how can one go about it?CheersMariusz
Mariusz,I use 3 SLA (Sealed Lead Acid) batteries each of 6volts and about 7ah (Amp Hours)and connect them in series, they do tend to last - especially if you turn them off when not using!I keep two sets so that when one is exhausted I plug the charged ones in and re-charge the tired ones - I normally charge them overnight so 3 evenings before they can be re-used.I also use batteries (2 SLAs for the LSA) using the same method.Alan
Thanks Alanand was the difference noticeable?Did you had a chance to compare?Mariusz
What is the 2nd BPS for?Cool setup. Mariusz
I have some battery holders that I used for my Hagerman Bugle. I can swap out the power jack and show the battery holder wiring for those who want to try that. I'll post pics later tonight.
I have a question about adding a second set of outs to the B1 for a sub. Since the B1 is an impedance matcher will an extra set of out mess things up?
MariuszI had used a wallwart psu and then a small linear psu, after I changed to batteries I never went back - so I cannot say that it sounded better only that I felt happier with the sound.Alan
Rarely do I have an opportunity to contribute, but this is one of them. Others have probably read this from me, but here goes. I had a Trends amp back when and I tried it with a SLAB supply. It made the sound smoother. Then I tried it with the old wall wart, but with a cap across the input lines. It made the sound more dynamic, but just as smooth as the SLABs. My 3 cents (devalued dollar).
I tried the battery option with a Trends as well, and found I liked it better than the wall wart... but never tried the cap across the input lines of the wall wart. What value cap did you find worked best?
