0 Members and 1 Guest are viewing this topic. Read 96607 times.
twitch54,After a quick chat with Walter at Underwood HiFi, I found that there was an change that was missed by the literature...the cartridge is actually a MM not a MC. Damn but that makes a difference went setting the switches on a phono pre-amp. So, Walter gave me the correct settings. What a difference a day makes. The midrange opened up, the soundstage expanded and I suddenly remembered why I resisted digital as long as I did. So, with the setup done right, I'm smiling! Thanks,Walt
OK. Heres another one. When is the arm balanced properly? At first I use to balanace my arm to be perfectly perpendicular to the plith. But found that things sound better when I balanced the arm so that the stylus hovered just slightly above the album. Thoughts?Ric
I saw this the other day and was wondering what a moving coil cartridge might offer. My real p-mount question is... It's such a no-brainer compared to installing a standard mount... what's the opportunity cost in terms of sound quality?
Perhaps the best option is to amass a stable of TTs to really figure this all out?
Quote from: Miney on 28 Feb 2009, 04:05 amI saw this the other day and was wondering what a moving coil cartridge might offer. My real p-mount question is... It's such a no-brainer compared to installing a standard mount... what's the opportunity cost in terms of sound quality? It's worth a shot to hear a moving coil for yourself. I own the (now) $400 Ortofon X5-MC (non-p mount) and it does a lot of things right. It does several things wrong, too, like tepid bass and soft dynamics, which keep it from my top 5.Quote from: Miney on 28 Feb 2009, 04:05 amPerhaps the best option is to amass a stable of TTs to really figure this all out? Amass a stable of TT's and cartridges you might end up at (12 cartridges and 5 TT's now )But, there is no substitute for trail & error, so I'm dang pleased with what I've learned along the way.John
In my mind, the MC is a black hole to poverty. You don't see too many $5K MM's. In my book, Over priced and Over rated. They should be called OO.Wayner aa
A low output moving coil will require an additional investments in a pre-preamp, because the output is too low for a standard phono preamp. Even if you have a higher output moving coil, you will probably still want a pre-preamp because, you will hear noise (tube rush). So this an expense that you won't have with a moving magnet.
Another point to consider is the stylus shape. The most forgiving to issues like VTA and Azimuth is the elliptical stylus. When you have a line contact stylus, you will find that these adjustments are much more rigorous. All of this can provide amazing sound quality, but you need to be an audio techno bigot to go through all of this rigor. So starting off, I think that a good moving magnet with an elliptical stylus will be much simpler and less expensive. Then if you continue with this mania you can upgrade from a normal person to an Audio Techno Bigot!
Quote from: Wayner on 28 Feb 2009, 11:52 amSo starting off, I think that a good moving magnet with an elliptical stylus will be much simpler and less expensive. Then if you continue with this mania you can upgrade from a normal person to an Audio Techno Bigot!Thanks for the stylus info!As for VTA and Azimuth, along with all the other rigors of vinyl... that's really what I was trying to ask, and worded so poorly. My TT's a complete no-brainer: fully automatic, no VTA / Azimuth adjustability, plug and play p-mount cartridge, can't swap arms, etc... but dayum, after stuffing it with clay as well as a few other inexpensive tweaks, as long as the LP is clean, it sound so great compared to redbook. So what are the sonic advantags of the "real" tables, the ones I read about here that you guys know and love so well, and all the beauties I see on Agon etc, compared to my Technics?
