0 Members and 1 Guest are viewing this topic. Read 96583 times.
I'll go first! I have no turntable yet but would like to get into vinyl this year.Given that my record collection is less than 10 albums, do you feel it is better to get a 'starter' table around $500 to get a feel for it, or jump in around the 2k mark?My current issue is, if I buy cheaper and not sure I like it, then I may not be sure if it's because I don't have a good enough setup.If I jump in with both feet then I will have sunk a lot of money and not have much to listen to (at least initially). Plus then if I don't like it I will probably be out of pocket even more with resale values how they are.
- Next; What with this moving coil/moving magnet thing and how do you know what you've got. I've asked this question before, and was given good answers, but it apparently didn't sink in since I didn't remember it. Apparently, preamp choice depends on the type of cartridge you have?? I think.
Moving Magnet or Moving Coil - what's going on inside the cartridge means little to you...it's how much you like what it does. Without knowing what brand/color or seeing a pic of your cartridge it's impossible to guess what you have there. Nonetheless, in general MM (moving magnets) are cheaper and MC (moving coils) are more costly and tend to be more 'tweeky' (less for newbies and more for experienced types)
That is my question as well. Can all tables accept either type of cart?I have an old Hitachi linear tracking table from the 80's. My preamp does not have a phono input. I guess I need a phono pre to hook it up correct???
Quote from: TheChairGuy on 25 Feb 2009, 08:57 pmMoving Magnet or Moving Coil - what's going on inside the cartridge means little to you...it's how much you like what it does. Without knowing what brand/color or seeing a pic of your cartridge it's impossible to guess what you have there. Nonetheless, in general MM (moving magnets) are cheaper and MC (moving coils) are more costly and tend to be more 'tweeky' (less for newbies and more for experienced types)Regarding the type I've got; Apparently the factory arm on a AR-XA is non-changable. So whatever normally comes in the gray plastic headshell O.E. is what's in there.Thanks guys!Bob
How to gauge good vinyl? When looking a used records how does one "know" it will play alright? Is it a crap shoot? Obviously, perpendicular scratches are not good
