0 Members and 1 Guest are viewing this topic. Read 227653 times.
I assume that there would be no problem with housing both units in a single box and connecting them in parallel to a single 120V wall outlet?
In that inductor shown in the PureAC, I only see two leads, which makes me think it is a standard inductor not a CMC. Am I just not seeing the other two leads? It seems that one of those PureAC units would be easy enough to mod.
Are most folks using polypropylene caps or polyester?
http://www.audiocircle.com/index.php?topic=50284.0
I believe they are Vishay film caps. Here is the link from Gary (GBB) to find parts at digikey:Quotehttp://www.audiocircle.com/index.php?topic=50284.0
It looks like Mouser doesn't stock the 8100 series, but they do stock the 7100 series (similar, but rated at <=5A).
http://www.newark.com/jsp/search/productdetail.jsp?SKU=63K4088&CMP=AFC-TL10000001
Brad,Here is another link you can get JW8120 at Newark (it is cheaper):
