0 Members and 1 Guest are viewing this topic. Read 21012 times.
Interesting findings . . . I am surprised that the felix and switcher are better than the felix and your linear.
I to find it hard to believe that your linear does not sound as nice . . .
Did you align and solder these components on a pcb board in parallel like Occam suggestion? If it is possible would you post a detail pictures that you built the Felix in the aluminum box?
Tan et al, Paul mentioned in another threads that it would be ideal to keep the leads of the .01Uf cap as short as possible, that is, directly across the cmc leads.
Thanks Gary, you've pushed me over the edge into finally building a felix. Will that CMC pass enough current to feed a power amp or should it be used only for components with low current draw?Russ
valuable thread thxwhat i do not see are the values of the cmc's with the caps you mention their value's in uF but the cmc have also many values between mH - uH or is the value you merely look at the amperage? So you then take the highest value in mH which you can choose from with a certain amperage?
Note: Please do not abuse the free samples from Coilcraft or they, like many other parts manufacturers, will quit fulfilling the small orders from the hobbyists. Then you do a disservice to all of us diy'ers out there. They are cheap and they do allow small quantities, so don't be cheap yourself and pay for them.Sorry if that is totally obvious, but it needs to be said as abuse of free samples has spoiled a lot of good services diy'ers enjoyed in our forums. If you want to order less than the minimum quantity, order the minimum and then post on one of these threads that you have extras and someone is likely to take them off your hands. Its not that big of a risk @ $6/ea.
Quote from: JoshK on 1 Feb 2008, 12:56 amNote: Please do not abuse the free samples from Coilcraft or they, like many other parts manufacturers, will quit fulfilling the small orders from the hobbyists. Then you do a disservice to all of us diy'ers out there. They are cheap and they do allow small quantities, so don't be cheap yourself and pay for them.Sorry if that is totally obvious, but it needs to be said as abuse of free samples has spoiled a lot of good services diy'ers enjoyed in our forums. If you want to order less than the minimum quantity, order the minimum and then post on one of these threads that you have extras and someone is likely to take them off your hands. Its not that big of a risk @ $6/ea. JoshKI would totally agree with you and do not mean to attrack to people who want "free sample." Hence I ordered one. That is coilcraft offering though. Please do not misunderstand me. Thanks.Tan
