0 Members and 4 Guests are viewing this topic. Read 262964 times.
ebag4, If those sound as good as they look, they must sound fabulous!
Ed,As I mentioned in the other thread, absolutely gorgeous With the Platinum by-pass caps they take awhile to break in. Also, once you get the No-Rez in you will notice a difference. Using REW to set mine up at the Lone Star Audio Fest took the integration to a new level for me. $80 for a mic, $30 for a mic stand, free software, a bit of a learning curve for the software (not bad though, very easy to follow documentation), and about 4 hours of taking measurements and making adjustments was all it took. Mike
Ed, as usual youve knocked it out of the park again.Absolutely gorgeous.....not much more I can say.I hope you have many hours of listening bliss.... Perry
Near field setup.
