Lets see your O.B. speakers....!
jrubins
Re: Lets see your O.B. speakers....!
« Reply #340 on: 24 Apr 2018, 12:02 am »
Here's mine, both of them! Alon model One and some homebrew DSP being fed by a raspberry pi :)
https://www.amazon.com/photos/share/xHyoD4GDtBEoKaKPmbkhgoHUrgLia8hBIjNQdKy0yhq
opnly bafld
« Reply #341 on: 24 Apr 2018, 02:09 am »
Nice!
blerpa
« Reply #342 on: 30 Apr 2018, 08:25 am »
My just fixed OB proto 3rd generation.
Supravox 215rtf64 + audax tweeter+BD15 sub. Sub powered with Hypex class-D. Sub in N-frame, inspired by Nelson Pass. Supravox in mini-baffle inspired by Linkwitz.
The whole thing sounds very fresh and crisp !  This is the whole idea, to catch the OB openness
gils
« Reply #343 on: 3 May 2018, 01:19 am »
 :D
Hello all,
My new system test  Infraflex 36"  + U-frame 18" + compression 1"  with TPA 3116 :)
https://youtu.be/UuPiBPzsmcI
cdt.
studiotech
« Reply #344 on: 3 May 2018, 03:02 am »
:D
Hello all,
cdt.
Very nice.  Could you tell us more about that Infraflex woofer?  And what was the music selection in the  video?
Greg
gils
« Reply #345 on: 3 May 2018, 07:52 pm »
Hello Greg,
look good bass 20 Hz at 100 Hz  105 db SPL /W/m
U-frame 18"
a recording of my system with 2 microphones C2 Berhinger at 3 m
https://www.partage-fichiers.com/upload/dbgfwtkc
cdt.Gilles
Bob in St. Louis
« Reply #346 on: 3 May 2018, 08:07 pm »
Ran across this on Facebook.   :o
matevana
« Reply #347 on: 4 May 2018, 02:32 pm »
I guess he plans to stay single.
Bob in St. Louis
« Reply #348 on: 4 May 2018, 03:22 pm »
:lol: :lol: :lol:
erkki
« Reply #349 on: 22 May 2018, 08:14 pm »
And one more OB for the forum...  my first OB build.
Front panel: 16" x 32",  drivers: Eminence 15LFA & Celestion TF1225CX coaxial.
Hybrid XO, Celestion has passive XO, between Eminence and Celestion it is active. Frequencies are 200Hz & 1.9kHz.
Denon AVR-2106 modified to Bi-amp use with miniDSP 2x4HD.
After some months of adjusting DSP settings, I'm still not 100% sure of correct sound balance.. measurements in small room are just pain.
« Reply #350 on: 23 May 2018, 12:50 am »
Wow, very nice wood, do you would add a hat above the 12'':
erkki
« Reply #351 on: 23 May 2018, 06:21 am »
Thanks. Actually the varnish stain worked out much better than I expected, wood is just cheap spruce from Bauhaus.
About that hat, would it be for controlling the directivity pattern?
« Reply #352 on: 23 May 2018, 06:45 am »
Correct, it help more than looks.
Note that if the hat is a thin real wood flap it will resonate according the music, that can be good or no to the sound quality.
Chops
« Reply #353 on: 23 May 2018, 12:31 pm »
Almost nobody uses a "hat", probably because it has little to no effect at all on sound or directivity. If anything, it adds just a bit of bracing to the baffle.
« Reply #354 on: 23 May 2018, 10:03 pm »
Originally it was created to operate with bass freq which are less directional.
gils
« Reply #355 on: 23 May 2018, 10:51 pm »
 :D
Hello, run my system
https://youtu.be/uZGAyRrtW18
:thumb:
best regard
Chops
« Reply #356 on: 25 May 2018, 06:08 am »
Wings yes. Hat's? Not so much.
Chops
« Reply #357 on: 25 May 2018, 06:21 am »
Anyway, here's a quick pic of my temporary OB setup, just to break in the new Audio Nirvana Super 12's which are playing fullrange. Running a single Eminence Acoustinator N2012 Neo woofer per side to provide bass below 200 Hz, and they do extremely well in doing so, extending deep into the mid 30's.
Running a dbx Driverack Venu 360 for crossover duty only, 200 Hz @ 24 dB on the N2012 woofers. The AN Super 12's are getting a fullrange signal. Each OB is being vertically bi-amped by the Carver M-500t MkII amps.
The final OB will be very similar to the P.A.P. Quintet15, only using the N2012 woofers (four per channel) and the AN Super 12. Just ordered the last pair of N2012 woofers from Danny Richie last night. I can't wait to hear the final system results. These temp OB's already sound amazing!
gils
« Reply #358 on: 5 Jun 2018, 11:42 pm »
« Reply #359 on: 6 Jun 2018, 05:21 am »
:D
:thumb:
best regard
Great job, great music selection also, congratulations :thumb:
