0 Members and 1 Guest are viewing this topic. Read 44044 times.
I stream everything from a Synology NAS, works great.
I have installed the M2Tech Evo drivers on Windows 8 full release and prerelease versions in compatibility mode and it works correctly here without issues. Did you do the install the driver from the Desktop environment? I used the Windows 7 driver with Windows 8.
If you connected the M2Tech Evo before the software driver was loaded on the machine that might cause a problem. Do not connect the Evo during the following process until you are sure the driver is loaded.First go the the Control Panel, look at Programs loaded and see if the M2Tech driver software shows as being installed. If, so try connecting the Evo to a different USB port and see what happens. If you do not see it in the list do not connect the Evo yet.If it is not installed, go to the Windows desktop panel in Windows 8, open up the file folder. Find where the M2Tech Evo Windows 7 driver file is located.Double click the Windows 7 version M2Tech Evo driver. It should then install. After you are sure it installed, then connect the M2Tech Evo.You will need to select the Evo as the output device in your JRiver MC17 music player.
There is a small switch on the front of the SOTM card. It allows you to either use or not use the C.A.PS. As the power source for the USB. Try the switch in the other position.
