0 Members and 1 Guest are viewing this topic. Read 54923 times.
I am in Houston airport and coming back from week long travel, arriving midnight tonite. I will chime in tmrw if this is still an issue. Make sure power molex is attached to SotM card. And makes rue m2tech driver is installed, probably in win7 compatibility mode.
Sorry, typing on iPad. It should have said make sure m2tech driver is installed, and you might need to install it either in win7 compatibility mode, or maybe in safe mode called disable-digital-signature
What is shown when you go to the lower right and right click on the speaker? What devices show up in that window?
in win7 compatible mode , i have no idea how to do that .
it shows: Digital Audio (S/PDIF)is this your last device that you ran on the caps ?
No my last default was ODAC.
For reference in the thread that ted_b posted, I did the Windows 8 install for the M2Tech without seeing the pane that the thread posted about the Thesycon driver. The M2Tech Evo version 1.03 driver always worked well with the motherboard USB driver. This was with both the Windows 8 preview OS and the full version OS installs. Have you contacted the SoTM USB card folks about this issue to see if they have any suggestions?
see how fidelizer works
