FS: David Berning EA2-150 amplifier
0 Members and 1 Guest are viewing this topic. Read 5761 times.
Whitese
« on: 23 Oct 2011, 09:29 pm »
price: 1100.00 plus shipping
Very sweet and powerful Berning EA2-150 amplifier.
It was converted by previous owner to use 6KG6A (EL509) instead of the 6FL6 tube. I have 2 spares that will go along with the amp.
It uses 4 6KG6A output tubes and 6 12AT7's.
Speaker impedances of 4, 8 and 16 provided for with 5 way binding posts.
Self biasing. ( I believe it was the first amp to do so)
It has feedback selection switch of 0, 8 or 16 dB. It also has a front toggle switch to limit output to 40 watts instead of 150 watts.
Its the sibling to the Audionics BA-150. Comes with some literature and schematics.
Looks wise, the front is very good, the chasis is strong and tight, the perforated surfaces (top and rear) show age. There is a slight hum coming from the main long black trannie that I tamed by putting some rubber between the trannie and side wall...Trannie mounts might need to be tightened, or the ground?
voltages:
In the instruction manual it says:
117 VAC, 50-60Hz up to 10 Amps
234 VAC, 50-60Hz up to 5 Amps
I think its the little orange wire in the plug that has to be relocated.
Ships from zip 07047, and its a 90 lb package.
Whitese
Re: FS: David Berning EA2-150 amplifier
« Reply #1 on: 30 Oct 2011, 12:55 pm »
Any interesting trades? SET amp?
Whitese
« Reply #2 on: 11 Nov 2011, 08:32 pm »
price drop and more pictures..1,000.00 including shipping.
« Reply #3 on: 11 Nov 2011, 09:17 pm »
Selfbias is the best bias system IMO, = long tube life.
This amp is the Z OTL circuit??
Freo-1
« Reply #4 on: 11 Nov 2011, 11:16 pm »
Disagree with the self bias comment.  Many designers use fixed bias setups, and the reason generally given is that fixed bias is superior over self bias sonically.
As always, YMMV.
« Reply #5 on: 11 Nov 2011, 11:24 pm »
OK. thanks for that info.
Whitese
« Reply #6 on: 12 Nov 2011, 12:39 am »
Its a c-mos digital logic biasing. It biases the tubes periodically during operation. the logic circuitry constantly measures and adjusts each tube individually.
At start up, there is no sound until the tubes reach a certain temp. and are biased.
« Reply #7 on: 12 Nov 2011, 01:00 am »
Hi,
Seems it is the Self Bias system you are referding to.
Whitese
« Reply #8 on: 12 Nov 2011, 01:56 am »
Hi,
yeah, I figured I better read the paperwork and give some info.
Whitese
« Reply #9 on: 12 Nov 2011, 01:58 am »
As always, YMMV.
Its not a Z OTL...
« Reply #10 on: 12 Nov 2011, 02:20 am »
OK, thanks  :thumb:
