0 Members and 1 Guest are viewing this topic. Read 26406 times.
I'd like to differentiate between my commercial four-sub system, which I call the "Swarm", and a fullbore Geddes system; the former is simpler and the latter more advanced. My system uses a single central amplifier to drive four small subs. The four small subs have an inherent rolloff that is approximately the inverse of anticipated room gain. The single central amplifier has a 4th order lowpass filter to aggressively roll off the top end of the subs. I suggest a few rules of thumb for placement, fiddling with levels and crossover frequency and (if necessary) using the single band of parametric EQ in my amplifier.If I understand correctly, Earl uses three or four subs which each have their own amplifier, and he takes advantage of that to optimize each sub individually for level, low-pass frequency, and phase. He is also using mains that are very low-Q sealed box systems, so he uses a different protocol for getting a good blend with his mains.
Thanks for bringing it back to Cheap and Cheerful rascal. From my memory of it, Geddes says you don't need expensive subs to make his system work, and he used three modest LF cutoff subs and one real sub. Thus you could use three of the 8" "subs" (I'd call them woofers, not sub-woofers) and one of the 12" for a C&C distributed sub system. They all have their own amps and you simply need a divider, help me out here I think it's Behringer that makes one?
Does it really matter the size of the sub, really? I mean what if you used very high quality 8's with big motors?It has to be more about the band of freqencies played, rather than the size of the woofer cone, huh? 8's are subwoofers too! Maybe not in this case, but last time I checked, they make subwoofers with 8" drivers. If we're talking music, not movies, and 30hz is about what you need for that, what's wrong with 8" subs? Especially in a small room? And why wouldn't an 8" swarm work in a small room? Why does it have to be tens? BUT.. those Polk 10" look like they could be good, they have phase control... $99. However, I believe the 12" Monoprice sub coming in Jan has all those things, phase, crossover, and 150 watts to boot.
I have to admit to you Doug, I've not spent much time at 20hz, I'm probably missing out . Hopefully someone can help me with the apparently complicated task of making these Brahma's OB subs. I think now I would rather do that if possible, because I assume they would sound much better than 4 cheap subs in a swarm because I listen near field, pretty much.
I'll have a $2500 pair of MMG's (omg) with all that tally'd up.
Oh, im scheduled to get the Magnestand mod done some time in Dec.http://www.indiespinzone.com/magnestand.html
And if you delay the multi-sub approach for a bit, he's a tweak that can achieve much of the same results, albeit only if you have one listening seat. With the woofer pointed to the side, place your sub with the woofer center exactly, I mean exactly, within 1/4", of the distance to your main speakers from your listening seat. Turn any phase control to zero. Make sure the sub is mounted rigidly, preferably on wooden blocks, maple is best, or spikes if you insist. I'm not going to tell you what it will sound like, just try it and report back.
What do you mean delay? As in ms delay? How many subs?
