0 Members and 1 Guest are viewing this topic. Read 26409 times.
four subs in a multi sub layout, only that four is easier to integrate. Three can work just fine.
They will work. Qts of 0.47 isn't that low, and you'll need power and EQ. But you are going to need those anyway.
And to JTTrace.. Wow! So you have four subs, two pairs of different types, huh? I can only imagine how that sounds.
You've had OB's before right?
It seems like the upper echelon uses either OB or multiple subs, but it seems like OB is falling out of favor for the multi sealed sub approach.
But then, who has tried a swarm of OB subs?
That's correct. OB is NOT the way to go for multiple sub system. Remember, it takes about double the about of drivers for the same output. To me, that's one of the disadvantages.
TomS I think your style of setup is what I aspire to.Anyway, after reading all that, it appears that "random placement with differing elevations" didn't work in your room? I got the impression the swarm was easy to set up, that you placed the 4 subs randomly and that it didn't really matter so much where they were placed. I think someone said they tried arranging the subs in different spots and it all pretty much sounded the same....
I need to go in on monday and possibly buy a new charger. If I can I'll try and swing by rat shack for an spl meter, and hit up Fry's for a cheap external soundcard that can mate up with it (I run a cheap laptop, nothing more than headphone/microphone minijack connectors), dl some software, and start measuring.
While SPL meter is not a bad thing to have, for this I think you'll need a mic like the Behringer or Dayton from Cross-spectrum labs. Read all about it here: http://redspade-audio.blogspot.com/2010/08/basic-measurement-setup.html
while it's getting off-topic perhaps others could chime in with the hardware they use.
I think meanwhile I'm going to bug JohnR about getting these Brahma's in an H frame.
There is more to gain with meassurements then swapping out your hardware.
Pre-warning: My setup is not really cheap and cheerful, but many of the same ideas can be applied
I suspect the resulting very high model density is what makes the bass sound ...
I got the impression the swarm was easy to set up...
