0 Members and 1 Guest are viewing this topic. Read 54978 times.
TONEPUB, Can you give us an idea of the ways you see yourself and MF as being on different pages? That will certainly be helpful to help those of us reading your and his reviews and columns triangulate where you stand. BTW, many thanks to TONEPUB for donating MusicDirect LP of your choice gift certificates to yesterday's ChiUniFi headphone meet. I was lucky enough to win one. Thinking it is time to pick up that new DSOTM, unless TONEPUB has another recommendation...
We're working on getting the memory player, I'm hoping to see it after CES.As for the empire, we've been waiting for a Paschetto Empire. I don't have enoughhours in a day to restore a turntable at this point. When Mike has the time to sendus one of his, we'll give it a run through, and because I have a pair of SME 309 arms,identical Furutech tonearm cables and a couple of pairs of cartridges, we can compare itto a few things side by side and actually see what it is capable of.
But I've heard way too much PF in the last month! My ears are numb.
the only problem with that is it isn't something that's really a reliable sample to judge.you can always save a few bucks if you refurb/restore something and comparing that to a new table for $2500 is apples to oranges. We really don't do a lot of DIY for that reason.It's not something that you can get readily repaired if something goes wrong, either, and it's not anything that's readily available. We did an article on the guy from Fix My Dual, because he has a steady stream of replacement tables and repair parts, but this is a little bit out of the realm of what we normally cover. Not to say that we might not approach it in the "analogaholic" section of our website one of these days, but for now, too much on the front and rear burners!
I just found this thread, and since there is a discussion of empire tables, thought I would throw in my empire story.Around 2005, I decided to give vinyl a try. After some research, I bought an old empire 298 table. My main reason for picking the empire was the bearing. Their bearing was manufactured to very tight tolerances. When you spin an empire platter, you can tell.I guess it was me, but I could figure out a good way to change the arm, and still use the existing emprire plinth. I know I could have made an armboard, but at the time I was wondering how to get the vertical alignment right if I made an armboard.So, I ended up building a corain plinth, and while I was at it, I outboarded the motor. I threw on a modded Rega arm, built a Cornet for the phono stage, and spun some vinyl.It did sound good, and I used that setup for a year or two. But I got lazy after getting a squeezebox. Being able to pick any song in my library with a few button pushes is just too easy, so I now have to admit that my vinyl setup is neglected, gathering dust.Randy
There is a review by Mr. Fremer in this months Audiophile (December, Vol.34, No. 12) magazine in which he states the Rega RP3 "runs fast" by .1 to .2 rpm. He also made comments about the "quality control" of such inexpensive tables.To that end, I know that most, if not all of the tables parts are made with CNC machines or are molded to tight tolerances, therefore, the comment is a bit ambiguous.He also said the new RB303 tonearm is die-cast, but I think it's investment cast myself.A comment by Roy Gandy said the results of the TTPSU speed controller can't be quantified. In other words, may do actually not one thing.Still unaccounted for is the speed alteration caused by an engaged stylus.Wayner
The REGA arms are in fact die cast. I've been to the factory (twice) and have seen the actual die. As for the speed error, I talked to the us importer and they said that the table measured perfect accuracy before it was sent out. The one we reviewed and a good friends RP3 (which was a random stock item from music direct) both measured 1000 hz on the nose when playing a test tone.And, if you've listened to a pair of p3's side by side, one with ps and one without, the diff is clear. But fremer hasn't done that either.The quality control at REGA is very high. As any decent mfr will tell you, it's always better to get it right the first time, rather than ship out defective product and have to deal with it in the field...
