SPDIF: Two gate outputs are connected to Vss via capacitors, why ?
0 Members and 1 Guest are viewing this topic. Read 1082 times.
Whizzer
In the SPDIF input circuit of my DAC (DA500) I found two 74HCU04 gate outputs
are connected to Vss via capacitors in the board layout (gate inputs are at Vss)
but left unconnected in the schematic diagramm. What is right and why ?
Whizzer
Are you all just bakery boys without any technical qualification?
 :duh:
I'll try using 10nF myca to damp on Vss.
rollo
  • Rollo Audio Consulting -
   Yes sir just Bakery Boys here good luck.
charles
SMA
Whizzer
 :duh:
I'll try using 2.4nF myca to damp on Vss.
Sail away, away
Ripples never come back.
Gone to the other side.
(Genesis;)
rollo
 You come here insult us and want help.  :scratch:  Bye bye.
charles
SMA
