hollowcore doors
0 Members and 1 Guest are viewing this topic. Read 2046 times.
drummermitchell
hollowcore doors
« on: 4 Oct 2011, 02:39 pm »
Curious(as usual)regarding hollow core doors.
If you have a door(just back and across from your seating)if you have it sealed would there be any benefit to installing a acoustic panel on it or is it better to just install a solid exterior door.
It's not even close to 1st or 2nd reflection points.
bpape
    • Sensible Sound Solutions
Re: hollowcore doors
« Reply #1 on: 4 Oct 2011, 03:03 pm »
If you're looking for isolation into and out of the room, a solid wood door is a much, much better solution. A panel on the door will do little to nothing to stop sound transmission between spaces.  Doesn't mean seals aren't still a good idea - just not a lot of point putting them on a door that will pass sound so easily.
Bryan
drummermitchell
« Reply #2 on: 4 Oct 2011, 03:28 pm »
Thanks Bryan,kinda figured that,I imagine as my room has a bit of a hallway(away from seating position),
there is a stairwell(open)and about 6ft back and a couple of rooms at the back of the small hall,I'd assume even though their at the back that my bottom end is suffering quite a bit and that I should either close off my room or at least put solid doors at the back also,thanks.
bpape
« Reply #3 on: 4 Oct 2011, 04:02 pm »
A door will certainly help to control the amount of volume the system is trying to pressurize.
Bryan
mixsit
« Reply #4 on: 6 Oct 2011, 05:10 am »
This is just a shot in the dark here for fun but there is also the consideration that an opening is a very good trap' and may offer a variation to break up a room's dimensions.
drummermitchell
« Reply #5 on: 6 Oct 2011, 12:32 pm »
True enough as my computer room(5X5)is about 7ft. behind my couch and the bottom end sounds nice and full in there.
I actually like the sound better in there(my new HT room :o :lol:).
Maybe I can dig up one more pict of the hall.
drummermitchell
« Reply #6 on: 6 Oct 2011, 12:34 pm »
Slowly putting things back together from the front of room to THIS puzzle palace.
To the right is a stairwell and further down is another hidden door.
